I put it on the computer, rebooted, and I see nothing in network… USB is working quite well.
I tried with another computer without Haiku installed on it (only booting on Haiku’s USB dongle), nothing
I put it on winshit to check, it’s really RTL8188EU inside.
The current Haiku beta version does not support any USB Wifi adapters.
You need to use a nightly version which is not older than 2-3 months to get USB wifi support, the latest nightly should work just fine.
Also, the next Beta version is expected to have USB wifi support included.
You can find the Nightly downloads here: Haiku 64-bit | Haiku Files
Yes, it works now with Hrev 56541.
Wifi works immediately. Thank you.
I created a USB dongle and booted on with a CHUWI Larkbox Pro to test
(I did not find how to install Haiku on eMMC, it’s not recognized).
But I can no longer boot on Haiku’s USB key (with Hrev 56541) on my Lenovo ThinkPad T495, whereas I could with R1/beta3)… (can not evitate white screen with debug lines).
I tried a lots settings in UEFI/BIOS… none is working.
OK. I thought so.
I bought a Thinkpad T470 this morning… Hrev 56541 works very well on it.
Much more stable than R1/beta3 !
But the wirelass_card is written working on hardware.besly, and it is not, I use the TP-Link
It happens that components of computers vary within a series. The “function” or “non-function” is passed to us by the users, so we assume that this is correct if the message is “supported” here.
Have you read the information to this entry?
Had to set up mixed mode in bios with uefi first, othertwise wifi and soundard are not visible in uefi only mode.
~> sysinfo
Kernel name: kernel_x86_64 built on: Oct 20 2022 07:08:36 version 0x1
4 Intel Core™ i5-7300U, revision 806e9 running at 2700MHz
I still can not register on the bug reporting site !!
I must be stupid but it displays
Warning: Are you human? If so, try harder…
I don’t understand why I can’t register ! What does this sentence mean ?
it’s probably the same bug yes.
I shall add something funny…
The idualwifi7260/0 sometimes shows the SSID of the network to which the TP-Link TL-WN725N is connected
