The fundamental parts of the journal code are finished. Although they still need more testing, and they can change as more of the Ext3 code is written, they are ready for supporting the first steps in write support for ext2 and ext3 volumes. This blog post explains the code, and how it is organized to handle ext2 and ext3 volumes. The first thing to notice is that a journal only exists in Ext3 volumes, and therefore Ext2 volumes should not have their operations logged. However, having support for transactions makes it easier to handle error checking in file system operations. Because one operation (in most cases) is composed of many sub-operations, a transaction groups all of them to represent one operation, as if it was an atomic operation. The transaction then allows all operations to be “simulated” before actually applying them on the file system. Therefore, we can just do the sub operations in order, and if one of them fails, we can fail the transaction with the tranquillity that all the other sub operations will be undone.
This is a companion discussion topic for the original entry at https://www.haiku-os.org/blog/jvff/2010-08-05_ext3_journal_implementation/
