Hi,
I have installed the package examples for QTCreator but I can’t access to there by the QTCreator interface.
The only way I found for compile it is by copied the examples directory of QT to my home “Projects” directory.
Is there a better way for access and compile QTCreator examples?
Thanks
3dEyes
I don’t quite understand what’s wrong?
Is your Examples section empty?
Hi,
yes is empty on my virtual machine.
Apparently it work on your installation.
I have installed examples manually from haiku depot after qtcreator.
3dEyes
4
Try delete QtCreator settings - /boot/home/settings/QtProject/
Hi Again,
I don’t find the settings directory in /boot/home/
but I find a QtProject folder in /boot/home/config/settings
I think that it but after deleting this directory the trouble persist.
In exemple windows I have this label:
Qt 5.15.2 in PATH()
And a blank page.
