Drag[en]gine Game Engine
I decided to create an own topic for the Drag[en]gine Game Engine decoupled from the OpenGL Mesa Problem Topic with the 1.3 release.
Home Page of the project is locate here: DragonDreams
The full Changelog of the latest release is here (perma-link): Changelog Latest Release
Game development information can be found on the Wiki: Developer Wiki
Source code can be found on GitHub: GitHub Repository
Example projects are on GitHub too: GitHub Examples
And eventually the IndieDB News Article
As with the 1.2 release the Mesa problem is still present. Waiting for the Mesa bump in HaikuPorts. No GUI tools yet under Haiku (no gui-launcher nor IGDE). That comes when I looked closer at the UI API in Haiku.
For HaikuPorts the Pull Request is pending, then you can get it over HaikuPorts.
Anyone could build the new changes made in the PR, I’m not merging it as I don’t know the ins and outs for MESA, I’ll leave that up to the core developers to review, but glad you are still checking and reporting this! :slight_smile:
The PR is not for MESA but for the 1.3 release recipe. More or less the 1.2 copied and adjusted to pull the right v1.3 git tag.
Could you delete the 1.2 recipe in the PR? This way the changes are more visible :slight_smile: And reduces git noise :slight_smile:
I thought the old receipts should stick around. But no problem. I delete it right away.
If there is no issue bumping a version than it would be good to only keep the current working version (PS, didn’t check the build, but previous one was ok)
No, by definition dragengine builds are always strictly backwards compatible both for developers and gamers. I also check if it compiles and runs on my 64-bit Haiku. Can’t speak for 32-bit but that should work too.
Updated now the PR by removing the 1.2 recipe.
Saw it, let me try to boost a 32 bit build here to check
Merged, so no need to check for me :slight_smile:
Drag[en]gine 1.4 has been Released: https://dragondreams.ch/?page_id=307 .
Updated the HaikuPort receipt.
Pull Request: https://github.com/haikuports/haikuports/pull/5437 .
Drag[en]gine 1.5 has been Released: https://dragondreams.ch/?page_id=307 . News post with the changes.
HaikuPort receipt updated and merged.
While testing I noticed Mesa on my system does not like the new GI. Since 3D on Haiku is very slow disabling all this is useful. Since there is no Gui-Launcher yet for Haiku I’ve created a config file that you can download to get some values which at least make it run. 2D works better.
Download launcher.xml and copy it to /boot/home/config/settings/delauncher (create directories if missing).
To run it you still need the MESA_GL_VERSION_OVERRIDE env variable trick. To make it simpler here a script to run *.delgas with: runDelga.sh . Run it like this:
./runDelga.sh DEExampleApp.delga
Thanks for the notice, didn’t run it myself, but it’s good to know there is a solution for it :slight_smile:
Pull request for version 1.6 : https://github.com/haikuports/haikuports/pull/6269 .
I did not get around doing the release for Haiku since I had to prepare for a trade show so my time has been ultra scarce. Here some impressions if you like:
booth2
booth1
Drag[en]gine 1.7.1 released. Pull request: https://github.com/haikuports/haikuports/pull/6413 . The way is now paved to release DEMoCap: DEMoCap – Drag[en]gine Motion Capture – Dragon Dreams
Added “REVISION” back to the recipe, latest version is now available :slight_smile:
You two should get on terms with each other. One dev tells me to remove the REVISION, the other puts it back. :roll_eyes:
I think diver was taking about HAIKU_PATCH="", and not the revision line.
I’ve resolved the conversation already but one comment asked for removing HAIKU_PATCH and the following (by the same person) about removing REVISION line.
I only saw the comment after it was merged, @Diver mention to “'reset” the REVISION, not to remove it IIRC ?
I think I changed REVISION to 1 and then another comment asked to remove them. But I’m not 100% sure. I just need to know what is the right thing to do in the future.
