When looking at the extra attributes documentation, I noticed that the integer ranges indicate 2’s complement unsigned integer magnitudes but have the symbol for + or - that value indicating signedness. Is it signed or unsigned? If it’s signed, the magnitudes are double what they should be. If it’s unsigned, the sign symbols need removing.
Thanks. After a bit of experimenting, turns out it’s signed integers indeed. Changed to:
- 8 bit: -128 to 127
- 16 bit: -65,535 to 65,534
- 32 bit: -4,294,967,295 to 4,294,967,294
- 64 bit: -18,446,744,073,709,551,615 to 18,446,744,073,709,551,614
Except the range of -65536 to 65535 requires 17 bits. It should be -32768 to 32767 for 16 bits. Likewise the max signed value of 32 bits is 2 billion something. It’s computed as 2^(n-1)-1 for maximum and -(2^(n-1)) for minimum. 2^n is the total number of combinations of patterns, positive and negative.
Whoops, you’re right. I forgot and only halved numbers for 8bit…
Will fix.
Thanks! I was starting to look where to file the patch against but the workshop portion of the userguide doesn’t appear to be part of the HaikuWebsite repo.
The user guide is managed entirely in the “userguide translator” app and not in Git. Editing it is behind a specific login wall. Hopefully iy will sometime be converted to the new Haiku Single Sign-On?
