Has anyone ever written a script for haiku, through which the background image changes every 10 minutes? I’ve seen something for the change after each reboot but it would be nice as
with the Mac, if you get between times a new background.
Try BeOS tool called “Cycler”, it works on Haiku.
Thank you, i will give it a try if i found them
Look at BeShare. There is in both formats: ZIP and HPKG.
Is the source code available somewhere?
