Hi guys,
I’d like to offer a little hint, esp. to new users that don’t have a BeOS history.
You can add any application, folder, query, link or document as a replicant into the Deskbar tray by entering in Terminal:
desklink {application, folder, query, link or document}
A click on the new icon opens the object. But that’s not all! You can create a context menu for it to offer other options. For example:
cd /boot/system/apps desklink "cmd=Active window (2s):Screenshot --window --border --delay 2" "cmd=Remove replicant:desklink --remove=Screenshot" Screenshot
This adds one menu item “Active window (2s)” that calls the Screenshot app with the commandline parameters to take a screenshot of the active window, including its border, after giving you 2 seconds to quickly activate your target window.
The second command adds a menu with the commandline to remove the replicant itself again.
Cool or what!?
