Delete column in columnbox
Hello, is there a solution to delete a column or all columns in the Bcolumnboxview.
If you mean BColumnListView, there is a method RemoveColumn(BColumn* column).
Hello BlueSky,
Yes i mean BColumnListView. Did you use have this method. Do you know an example to use this method.
I think to use it RemoveColumn(BColumn* column) , column should be the index from the column. Am i right?
Nope, it’s the BColumn object you like to remove. You first need to get it, like:
int32 index = 4;
BColumn* removeColumn = theColumnView->ItemAt(index);
theColumnView->RemoveColumn(removeColumn);
Hello humdinger,
thank you.
I will try it.
