Hi,
The Linux kernel supports several mechanisms for delaying work (namely softirqs, tasklets and workqueues). I was wondering if there are any similar mechanisms in Haiku. The documentation doesn’t give any info and googling doesn’t either.
By looking for timers on the code I ended up looking at some accelerator’s code and it seems that they do any periodic work directly on the interrupt handler.
Thank you!
