Default safe mode booting
I am loving alpha 3, but in order to boot my machine I need to hold space at boot to get into the safe boot menu and deactivate an item. I’m just wondering if there is a system file I can change that will allow me to set that as a default boot option (so that I can just boot right into Haiku). Thanks in advance.
yes, most boot options can be turned on or off in a kernel text file. Found under:
/boot/home/config/settings/kernel/drivers
Enabling VESA mode is done by creating another text file.
https://www.haiku-os.org/community/forum/vesa_file_fixing_boot_problem
