I trying to compile various packages for riscv64 on real hardware and I often get cyclic dependencies error. For example CMake that it used by a lot of packages depends on itself:
> PYTHONHOME=/boot/system/ python haikuporter --no-source-packages --all-dependencies cmake
Warning: deactivating creation of source packages as 'git' is not available
Checking if any dependency-infos need to be updated ...
updating dependency infos of cmake-3.20.2
Looking for stale dependency-infos ...
dev-util::cmake-3.20.2
The following build dependencies were found:
/Haiku-nvme/data/haikuports/repository/ca_root_certificates-2021_01_19.DependencyInfo
/Haiku-nvme/data/haikuports/repository/patch-2.7.6.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libffi-3.2.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/rhash-1.4.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/diffutils-3.7.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libffi_devel-3.2.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/autoconf_archive-2021.02.19.DependencyInfo
/Haiku-nvme/data/haikuports/repository/gzip-1.10.DependencyInfo
/Haiku-nvme/data/haikuports/repository/rhash_devel-1.4.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/make-4.3.DependencyInfo
/Haiku-nvme/data/haikuports/repository/gawk-5.1.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/gmp-6.2.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/ncurses6-6.2.DependencyInfo
/Haiku-nvme/data/haikuports/repository/zlib-1.2.11.DependencyInfo
/Haiku-nvme/data/haikuports/repository/sed-4.8.DependencyInfo
/Haiku-nvme/data/haikuports/repository/nghttp2-1.43.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/gmp_devel-6.2.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/mpc_devel-1.2.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/tar-1.34.DependencyInfo
/Haiku-nvme/data/haikuports/repository/help2man-1.48.3.DependencyInfo
/Haiku-nvme/data/haikuports/repository/ncurses5-6.2.DependencyInfo
/Haiku-nvme/data/haikuports/repository/perl-5.32.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/bzip2-1.0.8.DependencyInfo
/Haiku-nvme/data/haikuports/repository/ncurses6_devel-6.2.DependencyInfo
/Haiku-nvme/data/haikuports/repository/zlib_devel-1.2.11.DependencyInfo
/Haiku-nvme/data/haikuports/repository/nghttp2_devel-1.43.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/pkgconf-1.5.3.DependencyInfo
/Haiku-nvme/data/haikuports/repository/mpc-1.2.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/m4-1.4.18.DependencyInfo
/Haiku-nvme/data/haikuports/repository/sqlite-3.34.1.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/bzip2_devel-1.0.8.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libuv-1.40.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/coreutils-8.29.DependencyInfo
/Haiku-nvme/data/haikuports/repository/openssl_devel-1.1.1k.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libiconv-1.16.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libpcre-8.44.DependencyInfo
/Haiku-nvme/data/haikuports/repository/sqlite_devel-3.34.1.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libuv_devel-1.40.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/openssl-1.1.1k.DependencyInfo
/Haiku-nvme/data/haikuports/repository/groff-1.22.4.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libiconv_devel-1.16.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libpcre_devel-8.44.DependencyInfo
/Haiku-nvme/data/haikuports/repository/readline-8.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/readline_devel-8.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/mpfr-4.1.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libedit-20210419_3.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libedit_devel-20210419_3.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/mpfr_devel-4.1.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/bison-3.7.6.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libtool_libltdl-2.4.6.DependencyInfo
/Haiku-nvme/data/haikuports/repository/autoconf-2.69.DependencyInfo
/Haiku-nvme/data/haikuports/repository/findutils-4.8.0.DependencyInfo
/Haiku-nvme/data/haikuports/repository/flex-2.6.4.DependencyInfo
/Haiku-nvme/data/haikuports/repository/gettext_libintl-0.19.8.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/grep-3.6.DependencyInfo
/Haiku-nvme/data/haikuports/repository/binutils-2.31.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/automake-1.16.3.DependencyInfo
/Haiku-nvme/data/haikuports/repository/texinfo-6.7.DependencyInfo
/Haiku-nvme/data/haikuports/repository/cmake-3.20.2.DependencyInfo
/Haiku-nvme/data/haikuports/repository/bash-5.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/gettext-0.19.8.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/gcc_syslibs-11.1.0_2021_04_27.DependencyInfo
/Haiku-nvme/data/haikuports/repository/libtool-2.4.6.DependencyInfo
/Haiku-nvme/data/haikuports/repository/curl-7.76.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/curl_devel-7.76.1.DependencyInfo
/Haiku-nvme/data/haikuports/repository/gcc-11.1.0_2021_04_27.DependencyInfo
/Haiku-nvme/data/haikuports/repository/python-2.7.18.DependencyInfo
Error: Port cmake-3.20.2 depends on itself
Any ideas how to fix this? Anybody tried to build all packages from zero?
Could you download CMake from the source and compile? There aren’t too many changes in the patchset file. It’s certainly not ideal, but might get you some progress.
I tried to compile CMake directly without HaikuPorter and I got this:
In file included from /boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/mutex:45,
from /Haiku-nvme/data/haikuports/dev-util/cmake/work-3.20.2/sources/cmake-3.20.2/Source/cmUVHandlePtr.cxx::
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:68:13: error: '__gthread_cond_t' does not name a type; did you mean '__gthread_once_t'?
typedef __gthread_cond_t __native_type;
__gthread_once_t
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:73:5: error: '__native_type' does not name a type; did you mean '__false_type'?
__native_type _M_cond;
__false_type
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:77:13: error: '__native_type' does not name a type; did you mean '__false_type'?
typedef __native_type* native_handle_type;
__false_type
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:159:5: error: 'native_handle_type' does not name a type; did you mean 'uv_handle_type'?
native_handle_type
uv_handle_type
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable: In member function 'std::cv_status std::condition_variable::__wait_until_impl(std::unique_lock<std::mutex>&, const std::chrono::time_point<std::chrono::_V2::system_clock, _Dur2>&)':
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:172:2: error: '__gthread_time_t' was not declared in this scope
__gthread_time_t __ts =
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:172:2: note: suggested alternative: '__gthread_once_t'
__gthread_once_t
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:178:28: error: '_M_cond' was not declared in this scope
__gthread_cond_timedwait(&_M_cond, __lock.mutex()->native_handle(),
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:179:7: error: '__ts' was not declared in this scope
&__ts);
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:179:7: note: suggested alternative: '__ns'
&__ts);
__ns
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:178:2: error: there are no arguments to '__gthread_cond_timedwait' that depend on a template parameter, so a declaration of '__gthread_cond_timedwait' must be available [-fpermissive]
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/condition_variable:178:2: note: (if you use '-fpermissive', G++ will accept your code, but allowing the use of an undeclared name is deprecated)
In file included from /boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/mutex:46,
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread: At global scope:
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:74:13: error: '__gthread_t' does not name a type; did you mean 'uv_thread_t'?
typedef __gthread_t native_handle_type;
uv_thread_t
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:79:7: error: 'native_handle_type' does not name a type; did you mean 'uv_handle_type'?
native_handle_type _M_thread;
uv_handle_type
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:85:28: error: expected ')' before '__id'
id(native_handle_type __id) : _M_thread(__id) { }
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:178:5: error: 'native_handle_type' does not name a type; did you mean 'uv_handle_type'?
native_handle_type
uv_handle_type
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread: In constructor 'std::thread::id::id()':
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:82:23: error: class 'std::thread::id' does not have any field named '_M_thread'
id() noexcept : _M_thread() { }
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread: In function 'bool std::operator==(std::thread::id, std::thread::id)':
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:283:16: error: 'class std::thread::id' has no member named '_M_thread'
return __x._M_thread == __y._M_thread;
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:283:33: error: 'class std::thread::id' has no member named '_M_thread'
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread: In function 'bool std::operator<(std::thread::id, std::thread::id)':
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:295:16: error: 'class std::thread::id' has no member named '_M_thread'
return __x._M_thread < __y._M_thread;
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:295:32: error: 'class std::thread::id' has no member named '_M_thread'
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread: In member function 'std::size_t std::hash<std::thread::id>::operator()(const std::thread::id&) const':
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:318:43: error: 'const class std::thread::id' has no member named '_M_thread'
{ return std::_Hash_impl::hash(__id._M_thread); }
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread: In function 'std::basic_ostream<_CharT, _Traits>& std::operator<<(std::basic_ostream<_CharT, _Traits>&, std::thread::id)':
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:328:23: error: 'class std::thread::id' has no member named '_M_thread'
return __out << __id._M_thread;
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread: In function 'std::thread::id std::this_thread::get_id()':
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:349:25: error: '__gthread_self' was not declared in this scope
return thread::id(__gthread_self());
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:349:25: note: suggested alternative: 'uv_thread_self'
uv_thread_self
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread: In function 'void std::this_thread::yield()':
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:357:7: error: '__gthread_yield' was not declared in this scope
__gthread_yield();
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:357:7: note: suggested alternative: '__gthread_once'
__gthread_yield();
__gthread_once
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread: In function 'void std::this_thread::sleep_for(const std::chrono::duration<_Rep1, _Period1>&)':
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:374:2: error: '__gthread_time_t' was not declared in this scope
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:374:2: note: suggested alternative: '__gthread_once_t'
__gthread_once_t
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:379:22: error: '__ts' was not declared in this scope
while (::nanosleep(&__ts, &__ts) == -1 && errno == EINTR)
/boot/system/develop/tools/lib/gcc/riscv64-unknown-haiku/8.3.0/include/c++/thread:379:22: note: suggested alternative: '__n'
__ns
Makefile:392: recipe for target 'cmUVHandlePtr.o' failed
make: *** [cmUVHandlePtr.o] Error 1
Error when bootstrapping CMake:
Problem while running make
Log of errors: /Haiku-nvme/data/haikuports/dev-util/cmake/work-3.20.2/sources/cmake-3.20.2/Bootstrap.cmk/cmake_bootstrap.log
That is why you need to start from haikuports.cross packages, which are cross compiled from another system where the dependencies are available. There is no way to build things starting just from haikuports recipes.
The main thing here is ueing “haikuporter --do-bootstrap” in your running Haiku image. I don’t remember what the switch does exactly. You don’t need to specify a specific package. It will rely on some prebuilt cross compiled packages to get started, and will rebuild everything.
When this was confirmed to work for the last time? I feel that haikuports.cross and haikuporter --do-bootstrap are no longer consistent anymore because of CMake, Python and other packages changes.
I think the last time the full process was run was sometimes in 2012 or 2013 when introducing the package management system to Haiku.
Since then they have been partial runs, of only the cross-compiling part for ARM and SPARC, and of the Haiku part probably by @korli when he worked on running gcc2 apps on a 64bit system (this required building packages for gcc2 as a secondary architecture, but I’m not sure how much of the bootstrap was used there).
