Customizing Haiku
Instead of creating a new topic for each single detail I need to ask I will use this thread for all of my small question. Now and the future ones.
  1. Sometimes my desktop icons (drives, volumes) got messed after restart. How work the internals of icons arrangement? I suppose there is kind of autosnapshot because some of them keep the place but, on the other hand, there are some magically moving elsewhere. I want them to be arranged in a column.
  2. Icon view. Why so huge margins and gaps? Are there a prefs for this?
  1. Is there a way to snapshot Tracker window settings (view, width of columns, columns arrangement) per location (path)?
  2. Is there more modules (third party?) for Deskbar? I’d like to have a horizontal bar showing overall memory usage and full date (freely configurable) next to the clock. Below an example from MorphOS.
    screenbar2
  1. The icons on my Desktop don’t move between boots… Maybe something gets messed up for you when you’ve un/mounted disks? I use the “Disks” setting to have all volumes in a window.
    If you haven’t already, check out the User Guide on Tracker (appearance).
  2. I think there was a bug/enhancement ticket for that already on Trac…
  3. Tracker already saves window configs. If you use single-window mode, the window size stays the same ofc.
  4. Don’t think there are any for that… (?)
For the last one, ProcessMonitor replicant show CPU core(s) activity as vertical bar(s) and next to it there is a memory usage single bar. But it’s small and without details indicator, indeed.
I think the first one may be the same thing I was noticing, that some tracker/deskbar configs weren’t remembered between reboots. It got solved somehow when I updated to nightly.
Ahoy Artur @Ostrowski ,
You can fix this if you move from R1B6 to Nightly.
The stuff that saves the status of desktop items on their place is broken right now – not needed to do additional experience with shutdown and/or reboot – both related.
It won’t cause a headache on Nightly branch - I promise, so I say better … would rather confirm it.
If that were the only benefit of switching from the stable build to Nightly, I’d rather wait for Beta7 :slight_smile:
Ok, it makes sense
– staying on Haiku Beta version, rather than jumping to Nightly
if the equasion in your case : the missing and not functioning well features are quite lesser than you gain with switching to Nightly.
On one of my laptop it was not a question : I gained so much by switching to Nightly, so I could confirm that all opened tickets can be closed as I won’t use it with Beta6 any longer.
There are still hickups, but just minor ones, meanwhile the Nightlies are not more risky choices - in case Haiku. You can remain on a specific Nightly version longer - not needed to roll over new patches so quickly as I did in case earlier years.
Now Haiku is more safe and as more focused on polishing, and also half of new contributors add patches that important for better experience with the functions that should work than as it works actually sometimes .. I rather use Nightly than Beta, where the new stuff just comes with time filter.
Sometimes in recent period, that I experienced as the annoying thing (for me) soon was discovered and someone patched, meanwhile earlier when I opened tickets about it, and those tickets were just there, and there were communnication issues by not understanding my problem, or debated my findings or else … So this way I worked for me that way … I stopped expecting and rather waited.
Recently I opened rather enhancement requests, but those were also questioned, so I will stop such those to issue. I leave it as is from now on.
Back to my chosen way …
If the OS cannot keep settings between boots – for me – is not tolerable. I judge it as major issue, so do not measure at all the risk, if any, especially if I must not upgrade continously … but rather : working as expected, or not ?
:cowboy_hat_face:
I’ve only really been exploring Haiku for about a month now, so I still have a lot to learn and dig into, especially since I don’t like just scratching the surface of an OS, I love getting deep into the nitty-gritty details.
That’s why I’d first like to get to know Haiku inside out in all the areas that interest me on this official Beta 6 release, so I don’t get sidetracked or spread myself too thin.
