Hi all,
I’ve compiled a media add on for Cortex (the IP Camera) - where do I add the compiled add-on so it shows up in the list inside Cortex?
Thank you!
Hi all,
Thank you!
~/config/non-packaged/add-ons/media
(or the system-wide counter part: /system/non-packaged/add-ons/media
In general, you place custom things under non-packaged
following the same dir structure you see under the read-only parts of /system/
You might need to Restart media services
(from the Media preflet) before Cortex sees it.
The “IP Camera” addon isn’t specifically an addon for Cortex, either; it’s just a generic media add-on. I think you can configure it as a default video source in Media preferences, without Cortex being needed?
Why is it not included in Haiku?
Ah thanks! That’s good to know!
