Hi
I installed Haiku x86-64-b1 in dual-boot (ubuntu 18.04) with EFI.
And have trouble configuring grub to boot on Haiku.
I commented “GRUB_HIDDEN_TIMEOUT = 0”
I copied these lines of code into “40_custom” , because “grub-costumizer” does not see Haiku.
"# for EFI systems
menuentry “Haiku” {
load_video
insmod part_msdos
insmod chain
search --fs-uuid --set = root
chainloader ($ root) /EFI/BOOT/BOOTX64.EFI
whith “grub-custumiser” or “update-grub” in terminal, he tells me that there is an syntax error on line 256 = "search --fs-uuid --set = root " ,
I doubt that it is necessary to replace “uuid” and “UUID” by the good values, but which one corresponds to the haiku partition and which one corresponds to the haiku boot file?
Also the location of “BOOTX64.EFI” is different on my Ubuntu (/boot/efi/EFI/BOOT/BOOTX64.EFI).
I must change “chainloader” ?
If a good soul has the courage to explain it to me
Thank you
This part should not be there I think. This is where your partition is mounted, but there is not such directory on it. In other words “($root)/”=“/boot/efi/”.
For me it’s normal , I haven’t directory /EFI/BOOT under /.
The BOOTX64.EFI has been installed by Haiku at this address ( /boot/efi/EFI/BOOT/BOOTX64.EFI )during the Haiku installation .
You need to install the EFI loader in your system EFI partition manually. The installer does not take care of this, yet. You can put it anywhere in your EFI partition, and then tell GRUB where it is so GRUB can execute it.
