[quote=Remco.Johannes][quote=Earl Colby Pottinger]
- Request: What computers are you trying to boot on, which Haiku-OS images were you trying to boot?
[/quote]
Intel dual core 2.8 Mhz
Intel 468 800 hz
Intel 386 300 hz
[/quote]
I don’t think the 386 and 486 are fast enough to use Haiku-OS useful enough. I could be wrong.
2) Note: I have had more problem getting x86_64 versions to work. But even they work when I cold-boot. Restarts have given me problems.
[/quote]
I used the ‘stable’ R1 Apha 4 (2012) anyboot image
[/quote]
I would try out one of the latest nighties as well.
3) Suggestion: Are you sure the USB stick is not buffered? [/quote]
Huh?
[/quote]
Most SD-Cards and some USB sticks have internal ram that allow quick bursts of data writes, but once the data is in the card it takes time to write it to the flash. If you pull such a device too soon the data is lost or corrupted.
This is more common in SD-Cards used in cameras, but since I have used adapters that turn a SD-Card into a USB stick, and since two of my laptops have allowed me to directly boot off SD-Cards while making them look like USB sticks to the OS - I can assume nothing about your setup unless you state it.
You may be removing it too soon. After the write operation have the Windows/Linux do a proper shutdown as this insures everything is written to the USB first. Next cold boot to the USB, do not try a restart.
[/quote]
I removed the usb -as recomented- via “the safeky remove hardware” taskbar button
[/quote]
I trust nothing, I trust no-one. That is why if things don’t work then I go all the way to shutdown to be sure.
Boot from a machine that was turn off. No sleep, no hibernate, COLD BOOT.
[/quote]
Done that
[/quote]
Note: I have 1 Acer, 2 Toshiba and 2 Dell Laptops - all boot fine from USB.
I also an Compaq Presario, two custom Desktops 1 a Celeron and the latest is I-7 machine, they all boot from USB. [/quote]
Lucky You ![:wink: :wink:](https://discuss.haiku-os.org/images/emoji/twitter/wink.png?v=5)
Remco[/quote]
I just wanted to point out that I have a wide range of machines to test Haiku-OS booting from the USB.
