Hello. Since is possible to have both packages (Qt4-dev and Qt5-dev) installed; how can I switch between them when compiling? In my case, qmake is “stuck” to Qt5, but for some apps I need to switch to Qt4.
Thank you!
Thank you!
I don’t know the specific solution for your problem. Maybe as a workaround, you could just move the Qt5_devel package out of /system/packages and move Qt4_devel in?
Regards,
Humdinger
Yes, removing the development packages is probably the only way, unless some tools are made available with a suffix (qmake4 or something like that?)
How is this handled in linux distros usually?
Hello. Apparently, in Linux there are the ‘qtchooser’ command:
http://manpages.ubuntu.com/manpages/utopic/man1/qtchooser.1.html
Another way, is using a environment variable:
https://harishnavnit.wordpress.com/2014/03/24/handling-multiple-versions-of-qt/
I’m not sure if in Haiku we could set in the same way.
