I am currently running into troubles with RISC-V port because something is crashing in 3rd-party libraries (libstdc++.so.6.0.25) that are provided as binary packages. This libraries are compiled with -fomit-frame-pointer that breaks stack trace and makes debugging much harder. Also it may be linked to old brolen glue code.
Is there an instruction how to compile HaikuPorts packages for different architecture?
Howver the process documented here expects that you already have a working Haiku install for the target architecture. If thatâs not the case, the normal process would be to always build in bootstrap mode (everything will be built from source). It takes a lot of time to do this because several steps are re-run everytime.
First you build Haiku in bootstrap mode. As part of the process it will cross-compile various packages, using the haikuports-cross recipes and the compiler flags from your gcc port (buildtools repo) and Jamfile configuration. This has to be done from Linux
Then you copy the packages to a Haiku install, and you use the script that will extract and repackage them, removing the â_bootstrapâ from the package metadata, making it look like these are the ârealâ, final packages
Finally, these packages have to be put in the âdownloadsâ directory of your generated/ working directory; and ideally also put on Haiku servers so that other people can use them. https://git.haiku-os.org/haiku/tree/build/jam/repositories/HaikuPorts/riscv64 needs to be updated if any package changes versions when you do this (usually not, there are very few updates to the haikuports-cross git repository).
Putting the packages on Haiku server requires root access there currently, so you have to ask kallisti5, waddlesplash or me to do it.
I never managed to get that working. In theory there is nothing that would prevent it, but the build fails in various ways and no one has debugged it.
It should be possible, but not easily accessible currently. Probably it needs adding more specific jam targets to run the builds, or run haikuporter manually.
BootstrapRepositoryFetchPackage1 /home/user/Packages/haiku/generated.riscv64-bootstrap/objects/haiku/riscv64/packaging/repositories/HaikuPortsCross-build/packages/icu_bootstrap-57.2-2-riscv64.hpkg
Checking if any dependency-infos need to be updated ...
Looking for stale dependency-infos ...
dev-libs::icu_bootstrap-57.1
The following build dependencies were found:
/home/user/Packages/haiku/generated.riscv64-bootstrap/../../haikuports.cross/dev-libs/icu_bootstrap/icu_bootstrap-57.1.recipe
Skipping download of source for icu4c-57_1-src.tgz
Validating checksum of icu4c-57_1-src.tgz
Error: Expected SHA-256: ff8c67cb65949b1e7808f2359f2b80f722697048e90e7cfc382ec1fe229e9581
Error: Found SHA-256: 6e5b3d0218a47698be3314c03863f061ebdad5ca0dc071441af83439a4fc7d5a
Supposedly built package /home/user/Packages/haiku/generated.riscv64-bootstrap/objects/haiku/riscv64/packaging/repositories/HaikuPortsCross-build/packages/icu_bootstrap-57.2-2-riscv64.hpkg does not exist; version mismatch?
package="/home/user/Packages/haiku/generated.riscv64-bootstrap/objects/haiku/riscv64/packaging/repositories/HaikuPortsCross-build/packages/icu_bootstrap-57.2-2-riscv64.hpkg"
if [ -e "$package" ]; then
exit 0
fi
haikuCrossDevelPackage="objects/haiku/riscv64/packaging/packages/haiku_cross_devel_sysroot_stage1_riscv64.hpkg"
if [ "x$haikuCrossDevelPackage" = "x" ]; then
echo "$package does not have a cross-devel package defined!"
exit 1
fi
if [ "x$haikuCrossDevelPackage" = "x${haikuCrossDevelPackage#/}" ]; then
haikuCrossDevelPackage="`pwd`/$haikuCrossDevelPackage"
fi
secondaryCrossDevelPackages=
if [ -n ]; then
for secondaryCrossDevelPackage in ; do
if [ "x$secondaryCrossDevelPackage" = "x${secondaryCrossDevelPackage#/}" ]; then
secondaryCrossDevelPackage="`pwd`/$secondaryCrossDevelPackage"
fi
if [ -n "$secondaryCrossDevelPackages" ]; then
secondaryCrossDevelPackages="$secondaryCrossDevelPackages,$secondaryCrossDevelPackage"
else
secondaryCrossDevelPackages="--secondary-cross-devel-package=$secondaryCrossDevelPackage"
fi
done
fi
portSpec=`basename "$package" | sed 's@-.*@@'`
cd /home/user/Packages/haiku/generated.riscv64-bootstrap/objects/haiku/riscv64/packaging/repositories/HaikuPortsCross-build
export LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/home/user/Packages/haiku/generated.riscv64-bootstrap/objects/linux/lib"
/home/user/Packages/haiku/generated.riscv64-bootstrap/../../haikuporter/haikuporter \
--all-dependencies \
--cross-devel-package "$haikuCrossDevelPackage" \
"$secondaryCrossDevelPackages" $portSpec
else
--cross-devel-package "$haikuCrossDevelPackage" $portSpec
fi
if [ ! -e "$package" ]; then
echo "Supposedly built package $package does not exist; version mismatch?"
exit 1
fi
...failed BootstrapRepositoryFetchPackage1 /home/user/Packages/haiku/generated.riscv64-bootstrap/objects/haiku/riscv64/packaging/repositories/HaikuPortsCross-build/packages/icu_bootstrap-57.2-2-riscv64.hpkg ...
BUILD FAILURE:
...failed updating 1 target(s)...
...skipped 16 target(s)...
...updated 75 target(s)...
Seems like a failed download or upstream changed the package as you get:
icu4c-57_1-src.tgz is not available anymore from specified URL. I downloaded it from different place, changed Haiku build system ICU version to 57.1.2 and that stage passed.
Now it creates source packages of a lot of HaikuPorts packages. Why it is needed? Will it pack all HaikuPorts packages? What is expected time to complete?
It creates packages for all haikuports.cross packages, it can take some time and it depends on your hardware (speed of CPU, disk, and downloads). It can be from a few minutes to a few hours the first time you run it. The next runs are a little faster because it can reuse existing packages, but it still is not very fast.
The following required ports will be built first:
dev-qt::qt5-5.15.2
dev-qt::qt5-5.15.2
/home/user/Packages/haiku/generated.riscv64-bootstrap/../../haikuports/dev-qt/qt5/qt5-5.15.2.recipe
Skipping download of source for 5.15.2.tar.gz
Skipping checksum validation of 5.15.2.tar.gz
Downloading: https://invent.kde.org/qt/qt/qt3d/-/archive/72b026a22e6942eca4b70ba948022aecbd8965fc/qt3d-72b026a22e6942eca4b70ba948022aecbd8965fc.tar.gz ...
--2021-05-28 16:00:56-- https://invent.kde.org/qt/qt/qt3d/-/archive/72b026a22e6942eca4b70ba948022aecbd8965fc/qt3d-72b026a22e6942eca4b70ba948022aecbd8965fc.tar.gz
Resolving invent.kde.org (invent.kde.org)... 195.201.182.103
Connecting to invent.kde.org (invent.kde.org)|195.201.182.103|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/octet-stream]
Saving to: â/home/user/Packages/haiku/generated.riscv64-bootstrap/../../haikuports/dev-qt/qt5/download/qt3d-72b026a22e6942eca4b70ba948022aecbd8965fc.tar.gzâ
haikuports.cross processing seems to be already finished, now it seems processing HaikuPorts.
Depending on what youâre trying to do, maybe you can stop there.
The ânormalâ bootstrap process is:
A lot of source packages will be generated and included in the image
You can then boot the bootstrap image
From inside the image you can run haikuporter, and compile all these packages from the prepared sources
I am not sure if this complete process has been used recently. Maybe @korli did it when working on the 32bit support for 64bit systems? When this process was designed, haikuports was a lot smaller than it is now.
However, for other architectures we had no way to actually run that image. So we did something else:
Build the bootstrap packages only
Use the âunbootstrapâ script to convert these packages to non-boostrap ones
Put these packages in the haiku repository (for this you need the help of @kallisti5, @waddlesplash or myself because it requires root access to one of our serversâŠ)
This appears to be sufficient to get Haiku built normally afterwards.
Note that this script uses the âpackageâ command, so it is easier to run it from an Haiku machine (after getting the hpkg files copied there, since the other parts of the bootstrap process work only on Linux).
If this approach works for you, we should probably make it the official one, and see if we can automate it. Unfortunately for other architectures we never got this running far enough to check if it actually results in a working system.
I managed to build gcc_bootstrap under Haiku, but some recipe changes were needed. --with-sysroot=/ cause attempting to use Haiku system libraries (mpfr) and fail because of incompatible architecture.
diff --git a/sys-devel/gcc_bootstrap/gcc_bootstrap-8.3.0_2019_05_24.recipe b/sys-devel/gcc_bootstrap/gcc_bootstrap-8.3.0_2019_05_24.recipe
index a44ec01..8d3330a 100644
--- a/sys-devel/gcc_bootstrap/gcc_bootstrap-8.3.0_2019_05_24.recipe
+++ b/sys-devel/gcc_bootstrap/gcc_bootstrap-8.3.0_2019_05_24.recipe
@@ -154,10 +154,10 @@ BUILD()
--libexecdir=$installDir/lib --mandir=$manDir --docdir=$docDir \
--disable-nls --enable-shared --disable-plugin \
--enable-version-specific-runtime-libs \
- --enable-languages=c,c++ --enable-lto --enable-frame-pointer \
+ --enable-languages=c,c++ --disable-lto --enable-frame-pointer \
--enable-threads=posix --enable-tls \
--with-pkgversion=$(echo $portVersion | cut -c 7-) \
- --with-sysroot=/ \
+ --with-sysroot=/boot/data/packages/haiku/generated.riscv64/cross-tools-riscv64 \
--with-build-sysroot=$installDestDir/ \
--with-threads=posix \
--with-default-libstdcxx-abi=gcc4-compatible \
@@ -303,7 +303,7 @@ INSTALL()
cd $installDestDir$installDir
$effectiveTargetMachineTriple-strip --strip-debug bin/*
- for f in cc1 cc1plus collect2 lto1 lto-wrapper; do
+ for f in cc1 cc1plus collect2 ; do
$effectiveTargetMachineTriple-strip --strip-debug \
lib/gcc/$effectiveTargetMachineTriple/*/$f
done
Never looked into other architectures for haikuports other then x86_64 and x86_gcc2 (and x86 for secondary), how do the packages get build if one would enable another architecture?
The buildbot atm is running the ones for 32bit and 64bit, but I donât know any other that are able to do this. Is this why you need the gcc_bootstrap for then? EDIT nvm, should have started reading from the start
