Hi all,
I have been testing Haiku for a few years with VMware and have used BeOS as my desktop in the distant past. I also still maintain (have not done anything in years) a functional Tune Tracker system on BeOS. Linux is my main OS these days with a little XP which I try to avoid.
I decided to try the Haiku alpha bare metal on my Thinkpads. The R50e worked great… audio (oss/Intel HDA), video and very responsive. My older Thinkpad A22m worked very well also… vesa video at 1400x1050 was very fast. The audio driver was not loaded and I think it should work.
It’s a CS4297A / CS4624 combo. The CS4397A is a Cirrus Logic AC’97 Audio controller which with Linux uses the Intel AC97 module (snd-intel8x0). The CS4624 is for Sound Blaster compatibility and uses the snd-cs46xx module with Linux. Note only one driver can loaded at a time with Linux and both do work fine.
See http://www.thinkwiki.org/wiki/CS4624 and http://www.thinkwiki.org/wiki/CS4297 for the details.
lspci and listdev show: Multimedia controller (Multimedia audio controller) [4|1|0] vendor 1013: Cirrus Logic device 6003: CS 4614/22/24/30 [CrystalClear SoundFusion Audio Accelerator]
I only need audio playback working so either driver would be fine. I think the OSS driver should work. How do I force the driver? I would prefer to use the Live-CD since I’m just testing but if needed I can make a Haiku partition.
