This is not neccesarily wrong. The listed devices there are logical devices, not physical. In this case your mouse exposes three usb devices… or some other device is exposing some. In any case, you can open a ticket, the best start is a syslog, the output of listusb -v and the usb_hid descriptor reports matching your device you can find in /tmp
(In any case, you can always just open a ticket without these things. we will then simply ask on the ticket for them)
I don’t know about the three mice, but the failure to notice the buttons is due to this mouse reporting position and buttons separately, in different USB events.
THE NEXT BETA!?? Ha ha, who knows how many betas it takes.
Anyway, it’s an awkward problem. There’s another problem with some Thinkpad trackpads, that come with external mouse buttons plus a button function within the trackpad. Here the position report from the trackpad, with its own button state, cancels out the external button, so the button appears to come up as soon as it was pressed down. Similar in that there are two button event sources; in this case the trackpad mouse-equivalent and the external buttons both register valid button state, but they step on each other (and the external buttons don’t appear in Input preferences.)
It would probably be good to put your issue on a ticket. There may be something interesting behind the triplicated mouse entry, you can participate in testing, etc. (I’m not sure my Cherry mouse is even usable at this point.)
Unless you have the exact same mouse as the other ticket feel free to open one regardless. You can’t tell from the outside if the root cause is the same
