As this is one of the very first time I’m using checkfs (haiku is running on bare metal), I cannot say whether this output is OK.
What does the message “names don’t match” mean?
Should I ignore it? Or: how does a clean checkfs look like?
Welcome to the Haiku shell.
~> uname -a
Haiku shredder 1 hrev56578+70 Feb 22 2023 07:26: x86_64 x86_64 Haiku
~> checkfs /dev/disk/scsi/0/0/0/7
xz_utils-5.2.5-2-x86_64.hpkg (inode = 2666563), names don't match
writable-files (inode = 2637526), names don't match
state_2023-01-14_15:20:10 (inode = 2666516), has blocks already set
activated-packages (inode = 2666525), has blocks already set
34454 nodes checked,
0 blocks not allocated,
7 blocks already set,
0 blocks could be freed
files 25324
directories 8833
attributes 153
attr. dirs 98
indices 46
direct block runs 34086 (2.74 GiB)
indirect block runs 611 (in 7 array blocks, 326.94 MiB)
double indirect block runs 0 (in 0 array blocks, 0 byte)
