Would be fine then you does not make a new website for it. You can send your tutorials to me or loglas from the besly knowledge base: http://www.besly.de, so your tutorials are on a position people can find it faster.
It’s jsut a tool that edits the password file for you (making sure that you don’t make a syntax error and prevent the OS from parsing the file and lock everyone out of starting a shell). Should be easy enough to write or port a version of it?
I guess it was not done because in Haiku, if you break that file, you can always fix it from the GUI. So the consequences aren’t as catastrophic as on UNIX?
Thanks a bunch for the insight. Over the weekend I was thinking of switching my default shell and searched the forums on the subject. I tried chsh knowing that it was most likely not supported. Not sure how useful chsh would be for the average Haiku power user.
