USB floppy drive are just as standard as USB disks. There is no need for a specific driver. It doesn’t matter if the manufacturer and distributor know about Linux or not.
The driver for internal floppy drives is unfinished and non-working, but the one for USB was working last time I tried it. Which I mentionned in this very topic a few posts earlier and this is why lelldorin has offered to test it again (I don’t have a working USB floppy drive anymore, so I can’t test it myself).
So it looks like the driver was broken somewhat recently and it is not working anymore. Is there a way to gather something useful from the KDL? Do you have at least an error message and a backtrace?
Actually, not fully true. Some PC ‘plug-and-play’ devices require specific software drivers or firmware/driver provided for the OS. Lessons learned from the “Winmodem” era. Some devices ‘download-and-install’ drivers to a compatible OS.
My little AMD desktop w/floppy drive didn’t KDL during Haiku boot up during Haiku R1B3 release.
I didn’t remember the floppy driver working at that time when I tested it during Haiku R1B1->R1B2, but
no KDL issues during boot.
Yes it is. USB floppy drives are standard and specific drivers are not needed.
Winmodems are not standard, each of them is different, and that’s why Linux driver developers never bothered to do anything with most of them. Get a standard modem using a serial port and AT commands, this is much easier to support, as the commands are standardized and a single driver is needed.
Maybe the driver should detect if it is a readable disk, or an empty one, and pass to the upper levels the correct status, so that the OS can show correctly that there is a blank disk inserted.
Can you give me the name and number of your external usb drive. I would add it to our hardware list and if i get it here in germany i can buy it for myself.
