I installed nodejs and npm from haiku depot… But when I tried to install hexo using npm, it returned an error. npm -g hexo-cli
returned the following error
code ENOENT
npm ERR! syscall mkdir
npm ERR! path /boot/system/lib/node_modules/hexo-cli
npm ERR! errno -2147459069
npm ERR! enoent ENOENT: no such file or directory, mkdir '/boot/system/lib/node_modules/hexo-cli'
npm ERR! enoent This is related to npm not being able to find a file.
npm ERR! enoent
I also cannot update npm for that matter.
What is the workaround if there is any?
/boot/system/lib is read-only directory. You need to use writable directory for installing NPM modules, for example /boot/system/non-packaged/lib/node_modules/hexo-cli.
Oh dear! That would mean uninstalling nodejs20 and recompiling nodejs from source.
I tried to designate folder within the system, say /boot/home/nodeprojects and then do:
npm init
npm install xxx
This process did create a writable node_module and package.json but it did not work. For example, I could not install vue_js or hexo that way. With vue_js, I came up against the problem of unrecognised os (this was also a problem with gradlew or gradle).
Haiku is getting more and more interesting, but a lot to learn every step of the way.
npm install hexo-cli is enough to install into ~/home (node-modules are installed there) you can also specify a certain prefix with: ~> npm install --prefix /boot/home/config/non-packaged/ hexo-cli
Thanks Begasus.
This works to install hexo-cli but hexo itself does not work after that and has issues with regular expression. Not sure what it means.
