Hello. I’m using the Canna input method, and I would like to know if there are a keyboard shortcut to switch between “hiragana”, “katakana”, etc (I mean, to swith between the different options of Canna).
The only shortcut that I found is “Alt+Spacebar”, but this is only to switch between “Canna” and the standard keyboard.
Alt + Space: Toggle input methods.
After changing to Canna, then input some Ro-ma ji text (ex. nihongonotesuto), then press space to start conversion.
Space: Select current phrase (Red background text) conversion candidate
F6: Change current phrase to Full width HIRAGANA
F7: Change current phrase to Full width KATAKANA
F9: Change current phrase to Full width Alphabets
Right arrow: Expand current phrase
Left arrow: Shrink current phrase
Up arrow: Cycle current phrase (HIRAGANA/KATAKANA/KANJI/Alphabet)
Down arrow: Ends current phrase conversion and move to next phase
Return: Ends conversion
ESC: Cancel conversion
For more imfometion, see default key binding file:
/boot/system/data/Canna/default/just.canna
