can HaikuDepot display speed rate as " pkgman install"?
when pkgman inatall wine_bin, it display the real speed rate .
but not with HaikuDepot.
as the front of pkgman, it should have the same information to display for user .
the user will be cray when it see the freezing progress of HaikuDepot without the value of real download speed rate.
This assumption is wrong, it is not a frontend to pkgman.
HaikuDepot is an independent application build ontop of the same library, the package kit.
(There is also a third called SoftwareUpdater)
Anyhow, this information could be displayed by haikudepot too but is not currently afaik.
You can open a ticket to suggest this addition on our bugtracker https://dev.haiku-os.org
