I discovered that Calligra apps were crashing due to failing to load the applicable mimetype (for the affected app). This issue is happening on Haiku R1B4 in my case (Haiku shredder 1 hrev56578+95 Jan 14 2024 07:14: x86_64 x86_64 Haiku).
Can confirm the issue, on 32bit it launches OK, on 64bit it crashes (had crashes before here but with my setup on this 64bit install I didn’t think much of it).
Looking at the “reported” missing file (both files are from Haiku package itself) and have the same date on both installs I’m not sure what’s going on here.
R1B4 on both installs too.
Looks like you are on nigly there, I’m still running R1B4 here, maybe there’s an issue there?
EDIT: Checked with a clean build in VMWare, on R1B4 64bit, works fine.
I wonder what gets messed up that is not recoverable?
