hi all
i’m trying to build a Qt webbrowser that compiles just in fedora 15,but refuses to build in haiku because of some sort of workaround in the code??(i think)
here is the error msg:
3rdparty/qtlocalpeer.cpp: In constructor 'QtLocalPeer::QtLocalPeer(QObject*, const QString&)': 3rdparty/qtlocalpeer.cpp:104:54: error: '::getuid' has not been declared make[1]: *** [../build/qtlocalpeer.o] Error 1 make[1]: *** Waiting for unfinished jobs.... make[1]: Leaving directory `/boot/home/Desktop/nowrep-QupZilla-1c6bd7e/src' make: *** [sub-src-make_default] Error 2 ~/Desktop/nowrep-QupZilla-1c6bd7e>
it’s probably not too difficult to solve but i’m not a c++ guy,so i hope to find some help here.
and here is the .cpp file in question
#include “qtlocalpeer.h”
#include <QtCore/QCoreApplication>
#include <QtCore/QTime>
#if defined(Q_OS_WIN)
#include <QtCore/QLibrary>
#include <QtCore/qt_windows.h>
typedef BOOL(WINAPI* PProcessIdToSessionId)(DWORD, DWORD*);
static PProcessIdToSessionId pProcessIdToSessionId = 0;
#endif
#if defined(Q_OS_UNIX)
#include <time.h>
#endif
namespace QtLP_Private
#include “qtlockedfile.cpp”
#include “qtlockedfile_win.cpp”
#else
#include “qtlockedfile_unix.cpp”
#endif
const char* QtLocalPeer::ack = “ack”;
QtLocalPeer::QtLocalPeer(QObject* parent, const QString &appId)
: QObject(parent), id(appId)
QString prefix = id;
if (id.isEmpty()) {
id = QCoreApplication::applicationFilePath();
id = id.toLower();
#endif
prefix = id.section(QLatin1Char(’/’), -1);
prefix.remove(QRegExp("[^a-zA-Z]"));
prefix.truncate(6);
QByteArray idc = id.toUtf8();
quint16 idNum = qChecksum(idc.constData(), idc.size());
socketName = QLatin1String("qtsingleapp-") + prefix
+ QLatin1Char('-') + QString::number(idNum, 16);
if (!pProcessIdToSessionId) {
QLibrary lib(“kernel32”);
pProcessIdToSessionId = (PProcessIdToSessionId)lib.resolve(“ProcessIdToSessionId”);
if (pProcessIdToSessionId) {
DWORD sessionId = 0;
pProcessIdToSessionId(GetCurrentProcessId(), &sessionId);
socketName += QLatin1Char(’-’) + QString::number(sessionId, 16);
#else
socketName += QLatin1Char(’-’) + QString::number(::getuid(), 16);
#endif
server = new QLocalServer(this);
QString lockName = QDir(QDir::tempPath()).absolutePath()
+ QLatin1Char('/') + socketName
+ QLatin1String("-lockfile");
lockFile.setFileName(lockName);
lockFile.open(QIODevice::ReadWrite);
bool QtLocalPeer::isClient()
if (lockFile.isLocked()) {
return false;
if (!lockFile.lock(QtLP_Private::QtLockedFile::WriteLock, false)) {
return true;
bool res = server->listen(socketName);
#if defined(Q_OS_UNIX) && (QT_VERSION >= QT_VERSION_CHECK(4,5,0))
// ### Workaround
if (!res && server->serverError() == QAbstractSocket::AddressInUseError) {
QFile::remove(QDir::cleanPath(QDir::tempPath()) + QLatin1Char(’/’) + socketName);
#endif
if (!res) {
qWarning(“QtSingleCoreApplication: listen on local socket failed, %s”, qPrintable(server->errorString()));
QObject::connect(server, SIGNAL(newConnection()), SLOT(receiveConnection()));
return false;
bool QtLocalPeer::sendMessage(const QString &message, int timeout)
if (!isClient()) {
return false;
QLocalSocket socket;
bool connOk = false;
for (int i = 0; i < 2; i++) {
// Try twice, in case the other instance is just starting up
socket.connectToServer(socketName);
connOk = socket.waitForConnected(timeout / 2);
if (connOk || i) {
break;
int ms = 250;
Sleep(DWORD(ms));
#else
struct timespec ts = { ms / 1000, (ms % 1000) * 1000 * 1000 };
nanosleep(&ts, NULL);
#endif
if (!connOk) {
return false;
QByteArray uMsg(message.toUtf8());
QDataStream ds(&socket);
ds.writeBytes(uMsg.constData(), uMsg.size());
bool res = socket.waitForBytesWritten(timeout);
res &= socket.waitForReadyRead(timeout); // wait for ack
res &= (socket.read(qstrlen(ack)) == ack);
return res;
void QtLocalPeer::receiveConnection()
QLocalSocket* socket = server->nextPendingConnection();
if (!socket) {
return;
while (socket->bytesAvailable() < (int)sizeof(quint32)) {
socket->waitForReadyRead();
QDataStream ds(socket);
QByteArray uMsg;
quint32 remaining;
ds >> remaining;
uMsg.resize(remaining);
int got = 0;
char* uMsgBuf = uMsg.data();
do {
got = ds.readRawData(uMsgBuf, remaining);
remaining -= got;
uMsgBuf += got;
while (remaining && got >= 0 && socket->waitForReadyRead(2000));
if (got < 0) {
qWarning("QtLocalPeer: Message reception failed %s", qPrintable(socket->errorString()));
delete socket;
return;
QString message(QString::fromUtf8(uMsg));
socket->write(ack, qstrlen(ack));
socket->waitForBytesWritten(1000);
delete socket;
emit messageReceived(message); //### (might take a long time to return)
I’m sure Haikuware would be happy to host and share it for you - have you tried submitting it to them yet?
