Building sum-it: rez needed
Hi,
I am trying to build the spreadsheet application sum-it from source.
This seems to require the resource editing tool rez. Does anyone know where I can get rez from?
Cheers,
Christof
Hi,
I don’t know where you got the source from, but the latest version at http://github.com/haikuarchives includes sources for rez.
Note that I made an haikuporter recipe for it, so it is very easy to get an hpkg file from it. I plan to add it to the package repository soon, along with some other packages I’m working on this week-end.
Great, thanks! I had an old version of the source.
Cheers,
Christof
otherwise Pe also uses rez and has the sources in the tree:
http://developer.berlios.de/projects/pe-editor
