I am following the Haiku build guide (Compiling for x86_64 | Haiku Project). I am getting the error -lsupc++ not found
when running the command jam -q -j2 @nightly-raw
(haiku) ➜ generated.x86_64 git:(master) jam -q -j2 @nightly-anyboot
Starting build of type regular ...
Building Haiku Nightly
AddHaikuImagePackages: package mawk not available!
Asked for bios_ia32 target boot platform
Unknown path to handle adding to image
Asked for pxe_ia32 target boot platform
...patience...
...patience...
...patience...
...patience...
...patience...
...patience...
...patience...
...patience...
...patience...
...patience...
...patience...
...found 108062 target(s)...
...updating 16685 target(s)...
MkDir1 objects
MkDir1 /home/praaagar/Desktop/Haiku/haiku/generated.x86_64/objects
MkDir1 /home/praaagar/Desktop/Haiku/haiku/generated.x86_64/objects/linux
MkDir1 objects/linux
MkDir1 objects/haiku
MkDir1 objects/linux/x86_64
MkDir1 objects/haiku/x86_64
MkDir1 objects/linux/x86_64/release
MkDir1 objects/haiku/x86_64/release
MkDir1 objects/linux/x86_64/release/tools
MkDir1 objects/haiku/x86_64/release/system
MkDir1 objects/linux/x86_64/release/tools/anyboot
C++ objects/linux/x86_64/release/tools/anyboot/anyboot.o
MkDir1 objects/haiku/x86_64/release/system/boot
MkDir1 objects/haiku/x86_64/release/system/boot/bios_ia32
MkDir1 objects/haiku/x86_64/release/system/boot/bios_ia32/revisioned
MkDir1 objects/linux/x86_64/release/build
MkDir1 objects/linux/x86_64/release/build/libroot
C++ objects/linux/x86_64/release/build/libroot/function_remapper.o
Link objects/linux/x86_64/release/tools/anyboot/anyboot
Archive objects/linux/x86_64/release/build/libroot/libroot_build_function_remapper.a
ar: creating objects/linux/x86_64/release/build/libroot/libroot_build_function_remapper.a
/usr/bin/ld: cannot find -lsupc++
collect2: error: ld returned 1 exit status
LD_LIBRARY_PATH="$LD_LIBRARY_PATH:/home/praaagar/Desktop/Haiku/haiku/generated.x86_64/objects/linux/lib" ../build/scripts/rm_attrs objects/linux/x86_64/release/tools/rm_attrs -f "objects/linux/x86_64/release/tools/anyboot/anyboot"
gcc -Xlinker --no-as-needed -Wl,--copy-dt-needed-entries -Wl,-rpath,/home/praaagar/Desktop/Haiku/haiku/generated.x86_64/objects/linux/lib -lm -ldl -lz -o "objects/linux/x86_64/release/tools/anyboot/anyboot" "objects/linux/x86_64/release/tools/anyboot/anyboot.o" \
-lsupc++ \
...failed Link objects/linux/x86_64/release/tools/anyboot/anyboot ...
MkDir1 /home/praaagar/Desktop/Haiku/haiku/generated.x86_64/objects/linux/lib
File /home/praaagar/Desktop/Haiku/haiku/generated.x86_64/objects/linux/lib/libroot_build.so
Ranlib objects/linux/x86_64/release/build/libroot/libroot_build_function_remapper.a
cp: cannot stat 'objects/linux/x86_64/release/build/libroot/libroot_build.so': No such file or directory
cp -f "objects/linux/x86_64/release/build/libroot/libroot_build.so" "/home/praaagar/Desktop/Haiku/haiku/generated.x86_64/objects/linux/lib/libroot_build.so"
...failed File /home/praaagar/Desktop/Haiku/haiku/generated.x86_64/objects/linux/lib/libroot_build.so ...
BUILD FAILURE:
...failed updating 2 target(s)...
...skipped 6 target(s)...
...updated 21 target(s)...
Please help
