I have installed Haiku (beta2) on a Acer Aspite 3820T. It runs graet, but I can only connect it over ethernet.
When I execute install-wifi-firmwares.sh, I get this error …
Compiling b43-fwcutter for installing Broadcom’s firmware …
… failed to compile b43-fwcutter.
…failed. broadcom43xx’s firmware will not be installed.
So I have inspected the script … it seems to download a file, b43-fwcutter-015.tgz. I have downloaded it … and the problem is that I have no make nor gcc … so I have intalled both packages … but now I have other error …
~/Desktop/b43-fwcutter-015> make
CC obj/fwcutter.o
In file included from fwcutter.c:33:
/boot/system/develop/tools/lib/gcc/x86_64-unknown-haiku/8.3.0/include/c++/stdlib.h:30:3: warning: #include_next is a GCC extension
include_next <stdlib.h>
/boot/system/develop/tools/lib/gcc/x86_64-unknown-haiku/8.3.0/include/c++/stdlib.h:30:16: fatal error: stdlib.h: No such file or directory
I have little experience with Haiku, so I cannot go further … Is there any package I need to compile it?
I will thanks any help, so I can use Haiku on this laptop.
@otosan69 : This firmware files required only by some very old wifi chips. Are you sure you have one of this old cards? Chances you can spare the pointless fight wih the script (for example it won’t give you support for BCM4312 based cards which is very common). Could you post your wlan card type?
Then you can stop right now as this card not supported at this moment on Haiku.
Haiku uses the bwi driver from Freebsd, but yours would require the bwn one, which is not yet available on Haiku.
Nice to know it is working for you…
How much did you pay for it?
I am asking since I like to know why some people prefer to wait for an driver instead to buy another card, if it is not that expensive!?
In my case, there are either no stocks nearby or the shipping will be costly and take a long time. I’m in the Asia-Pacific (SEA) area, unlike prolly most people here.
