I’m having a strangely hard time adding a BPopUpMenu to my custom BTextView.
I’ve tried several approaches, checked and double-checked the docs, and looked at some sample code - I am doing everything right, still don’t get any messages from menu items invocations.
I’ve added a simple context menu to my textview that overrides the native context menu.
For the items, I create fresh messages with some custom property.
The menu shows up just fine, but nothing happens when I select an item.
I’ve experimented with the async flag, made the menu a field just to go sure, added some logging to the view’s AND window’s MessageReceived function to check where it actually lands, but nothing ever shows up.
I am a bit puzzled now.
Any idea what I’m missing?
You can check the code at:
