I was thinking that it could be a cool idea if the BootManager progran was able to edit aspects of the bootloader’s configuration such as what Safe Mode options should be enabled by default.
What do you guys think?
The safe mode has not directly to do with the bootmanager. The boot manager (bootman) creates a menu for you to start haiku. Safe mode options controls things like vesa mode for the graphics card, etc.
To change the boot menu, run “bootman” from the terminal or open the Installer and select the bootmenu installation.
