I installed haiku to the nvme disk。When boot this os with edk2,it got stuck。
These are the last few lines when it appears to be stuck
Hi and welcome!
Not sure how to help you, but I added RISC-V to title to make it clearer to those who can.
What a hardware you got ? For Exapmle in vision five 2 is uboot without EDK2
Hello,
sifive hifive unmatched motherboard,UEFI EDK2
I have not tried RISC-V Haiku, but I’ve searched the forum a bit.
It seems no one tested EDK2+UEFI setup with real hardware successfully. X512 uses uboot on real hardware, uses EDK2 only with VMs(TinyVM, Qemu).
IIRC, the HiFive Unmatched motherboard is quite a massive high-end motherboard! It should be much beefier than the one x512 is using for RISC-V development. Haiku should fly on it if it ever gets debugged.
Actually its not. Its was quite overpriced when compared to the VisionFive 2. Yeah its got 16 GB RAM and a PCIe slot but the CPU is pretty weedy. It’s more comparabe to an RPi than an i3-i9 or a Ryzen, CPU wise.
The CPU may not be the culprit but its sad that the HiFive unmatched was so easily…er…matched. Maybe under Haiku, @kallisti5 will have better results.
X512 and I both have one (funded by Haiku, Inc). Haiku runs but it isn’t very stable yet. My plan is eventually mine will be a builder for HaikuPorts riscv64.
Things are looking up these last 24 hours ![]()
- X512 provided a great set of build-packages for riscv64
- I’ve massaged them into our build infrastructure
- haiku riscv64 now builds a nightly image profile instead of only the “minimal” profile
- I’ve cobbled together a haikuports repo from it as well. Keep in mind that these are all built by @X512 and might be unstable.
TODO:
- We’re missing stable python 3 packages on riscv64 (required to run haikuporter)… i’m attempting some manual compiling of python to get it going.
- We have some “unstable” python3/python2 packages, but they all do weird things like not support tar files, etc. (things needed for haikuporter)
- Once we get a stable python3 package, we should be able to start doing some initial builds (and rebuilds) of critical packages.
@edenzhang I would like to get EDK2 running on my Unmatched system as well. Can you point me at docs or builds? I don’t see it in the EDK2 platform list (just the unleashed)
@edolnx Hello, I developed it based on unleashed code
I would love to understand how you did that. EDK2 development is all new to me, but seems to be one of the few ways to get a video console using off-the-shelf PCIe GPUs. Are you willing to share your code?
@edenzhang Could you contact me via email instead of passing messages on this very old forum thread? I can be reached at caperry@edolnx.net
- Sorry, I was too busy to see the message
。the code is confidential ,I cannot provide
- If you want to use a PCIE graphics card, you need to implement the PCIE Enumeration in your code, refer to uboot
