drive setup,YEAH…
ZIE SPEEKEN ZIE DUTCHE?
—>I’m working as fast as the germans will let me.
translation takes a minute…
appears drive if done that way(used blank and formatted within HAIKU) installed with makebootable (and/or) dump of ZETA bootloader (dd onto /dev/disk/0/ata/slave/raw) gives the following message.
NOTE: this attempts to allow installation of bootloader on main system drive.
“the partition hooked up ON non removable disk lies too near at the beginning the non removable disk that boot managers cannot be installed”
(partition too close to beginning of drive)
here’s the rest of the messages you missed:
bootman:
SCBI BIOS not read.Please examine your drive to ensure they are setup correctly.
this error can also occur if ZETA between two non removable disks with identical partition tables to differentiate.this drive cannot be taken to the boot manager,as long as this is not solved,shall we continue?
login:
all of these existing programs are in copyright matters protected. that copy of data and programs on other carrier media, is not permitted also in part.
OH, YES, it boots okay.SLOOOOOOWLY, as does ubuntu from CD.Its the only one so far to boot natively. I get 300 fps+ on the coffee pot.
-tonestone57
the links are numbered 1,2,3,4,5,6,7 (.tiff) 1-5 and 6-7 are EXAMPLE numbers.server is up.doesn’t allow direct browsing.(THANK GOD)
Update:
found out 4.tiff was a duplicate file.
