Boost cleanups
I removed the 2 oldest version a short while ago, now I disabled boost165 and boost166 so buildmaster won’t try to use them if no boost version is set in a recipe.
If you run into problems related to this you can post a reply here or better open an issue at haikuports: Issues · haikuports/haikuports · GitHub
Thanks a lot for taking care of this :slight_smile:
