BOINC Client And project apps
Are there any plans to release new BOINC Client for haiku? And what about project apps? I’ve been trying to use BOINC on Haiku with a SETI app but it never finishes the workunit :frowning: I know some of the project have their source open. I really would like to have my HaikuBox crunch some WU’s
Should not be hard to compile BOINC client on Haiku. I think Urias compiled the current one.
The project apps have to be compiled too. So, you would need to find open source projects.
http://boinc.berkeley.edu/wiki/Anonymous_platform
Many projects have closed source code so you can’t use them on Haiku. Very few are open source (maybe 5 to 10? smaller ones).
Both the client and project applications have to be compiled on Haiku.
Indeed, I can update the BOINC client, but it won’t matter without project apps.
I have contacted a couple projects, who expressed interest, but then the discussion fizzled.
Maybe this weekend I’ll update the BOINC client and SETI app for Haiku :slight_smile: - one thing that is still missing from the BOINC client is proper AMD CPU feature detection support - I only completed the Intel stuff. I can do the AMD as well (I have an X2 5600+ here to test with), but it will take me some extra time.
  • Urias
Good news: It seems BOINC still compiles on Haiku, although I had to hack a makefile. I’ll fix that properly and work on the AMD features - then submit a patch.
As for SETI, I seem to recall some issues getting SETI units to complete as well - there was a “known issue” where the reference WU for SETI would hang forever on some machines, and when I asked about that, they said they didn’t know why it happened, and you had to stop/cancel the WU and try again when it happened. That may be the issue you’re running into.
I’ll try to build a new SETI app as well, hopefully that will help.
Gimme a few days, I’ll try to post the files somewhere and announce on http://teamhaiku.com
Lots of the projects are closed source. So, you either have to get them to open source the code or get them to compile and provide a Haiku version themselves. Neither one is likely to happen but asking never hurts.
Best to find 3 popular open source projects and compile a Haiku version.
from SETI site
"The project is down while we remodel our database servers."
SETI is down for now.
I know the administrator of Enigma@home and i can talk to to him. I believe that Einstein@home also has the source open.
So the list of project with open source apps is:
SETI@home
Einstein@home
Enigma@home
Orbit@home
Correct.
SETI was already ported shortly after I did BOINC (although I haven’t yet tried it again).
I was actually in discussions with people involved in PrimeGrid because it happens that many of their applications are derived from other apps that I have ported or attempted to port already; LLR (which I still need to work on some more - this code was horrible), mprime (already ported for SoB and eventually GIMPS), sr5sieve (which worked great for SOB/PSP sieving after I ported it previously):
http://primegrid.com/apps.php
Unfortunately, I need their cooperation to get the BOINC versions of those apps built for Haiku… and that was where things sort of hung.
Einstein and Orbit sound interesting - I’ll have to take a look at those. Enigma doesn’t interest me all that much, but if I find some time I’ll certainly take a look at whatever code they provide.
Bear with me - I’m trying to find some free time to work on this more :slight_smile:
  • Urias
Can You give some release date?
Project DNETC@home released app for haiku :smiley:
http://www.boincatpoland.org/smf/dnetchome/dnetc-net/msg124685/#msg124685
I patched the BOINC sources locally, but I still need to submit the patch. I wanted to rewrite the CPU feature detection, but I was disappointed in what I thought was going to be a better solution. Apparently all the necessary code is private to the Haiku kernel now, so I’ll have to re-create it anyway (similar to what I already did for Intel processors).
As for the DNETC boinc project - that’s probably just a thin shell wrapper around the dnetc client I ported. That client is also, unfortunately, a couple revs behind. I need to update it as well :stuck_out_tongue:
Running dnetc via a BOINC project is actually a really crappy idea. Yoyo@Home does this - and they get the credit rather than our own team. Better off just running the dnetc client directly and joining Team Haiku:
http://www.distributed.net/Download_clients
and
http://stats.distributed.net/team/tmsummary.php?project_id=8&team=30610
http://stats.distributed.net/team/tmsummary.php?project_id=27&team=30610
I just really would like to run my Haiku Box with BOINC and crunch :smiley: and i would like to encourage Haiku users to participate in the BOINC projects. In order to do that that BOINC client must be ported as well as project apps. I already convinced guys at DNETC to port an app for Haiku. It still have some problems, but i hope it can be solved. And i also hope i will be able to convince more project developers to port app for Haiku.
http://dnetc.net/hosts_user.php?sort=rpc_time&rev=0&show_all=1&userid=11
http://dnetc.net/results.php?userid=11
It seems to work. Maybe not perfect (0 seconds CPU time) but nevertheless
is there any progress?
