Ahoy @Malanow ,
I started this answer earlier .. today I could finish the post as re-checked the browser list and iterated test as well - you would find below !
For Haiku services
the best is Webpositive
If you cannot login onto the forum, then something went wrong with registration and/or Haiku installation.
You can bet on it – I installed all available browser - I mean those, which ones are packaged and are in repos - as I had not compiled any for myself from source (e.g. Ladybird newer patched version).
I do not say there is no issues - even with Web+ - sometimes, but I found reliable for Haiku related stuff.
You had written
you are on Haiku stable version , it could have not the reason for login had not succeded for you.
Stackoverflow worked for me in it, however I just browsed not logged in there.
Web/Epiphany browser lesser reliable, tends to forget bookmarks, and sometimes have issues, but for Youtube and GMail it is usable.
I dunno reddit site,
I just heard about that many ppl goes there hating and complaining about other reddit users - not a respectful, calm environment -
Not really understand why is it so good to visit then …
I assume it can have some peaceful small corners.
Back to Web - it was a bit resource hunger, now after a fixed memory leak it behaves better - just as Falkon.
Falkon is the most superior, if we see only the points gotten on HTML5 tests, there is adblock as well, just as in Web.
There is Dooble - it is also usable, but localization is broken, so english only its surface - if it does not problem for you.
Quite recent version otherwise : 2023-12-25
There is still Otter browser and Qupzilla (that is now the Falkon recently - its development continues in Falkon).
You can use them, but not for the latest full featured sites, as for Haiku Otter needs some upgrade to close the actual upstream version - so a bit old on Haiku and many protocols, services missing related to others I talked about.
Qupzilla is an older version of Falkon, I think it can be usable, however it won’t be developed on this name anymore.
There are some small simler browsers ported here, like Netsurf, Ladybird, Dillo Plus, Qutebrowser but their usage a bit limited - not only due to its engine, but the limited or lacking browser features as well.
Dillo Plus - fltk → TO VIEW THE RESULTS OF YOUR BROWSER YOU NEED TO ENABLE JAVASRIPT!
Dooble - QtWebEngine → 560 / 594
Falkon - QtWebEngine → 572 / 594
Kristall - unknown engine → To view the results of your browser you need to enable Javascript!
(Well it is mostly for Gemini protocol, but you can enable HTTP/HTTPS or even older ones, as Gopher, but seems : handling Java still had not added yet ! - in Settings there were no place to enable it )
Ladybird - of Serenity OS, unknown engine → 238 / 594
(It had surprised me how perform this level ..
really sorry that the newer version still had not shared on Haikuports by whom who ported that from among our forum members !! I thought it would render the Javascript message for me, but rather a result !!..
but really a bit messy in layout, however a real result, with details)
Links - character graphical, unknown engine → To view the results of your browser you need to enable Javascript!
Lynx - text based, in Terminal
MiniBrowser - WebKitGTK → 523 / 594
Otter - Qt + WebKit 602.1 → 396 / 594
Qupzilla - Qt + WebKit 602.1 → 417 / 594
Qutebrowser - QtWebEngine → 560 / 594
( Just as Dooble .. but the vim-like navigation within program .. well, it must used to learn and practice !..
Web (aka Epiphany) - WebKitGTK → 520 / 594
Webpositive - HaikuWebKit → 393 / 594
Kind regards,
