Hi…
What is the best Rudolf supported dual-head graphics card(s) available? Obviously it has to be from the GeForce 6 or 7 era to work with the driver. Also the card is going to have to be PCI Express and support two monitors at once. Any suggestions? I was looking at a GeForce 6200 dual-head PCIe card, but I think there might be a better option. Thanks!
Guru
http://www.bebits.com/app/1401
About Matrox/nVidia Dualhead Setup:
A simple utility to help setup the Dualhead and/or TVout features of Matrox and nVidia cards using the Haiku unified drivers.
Rudolf’s Haiku driver supports up to Geforce 7950 graphics card.
Yes, using a late Geforce 7 series video card would be the better option if you can find one. Should work since it uses haiku driver.
EDIT: since haiku does not offer 3d acceleration & you might not be into gaming anyways, going with the 6200 is alright too.
Hey thanks for that. Hopefully this will all work out. The driver does work fine with PCI Express, right?
Guru
Guru
