http://bs0.blogspot.com/2006/06/beos-userbars.html
I’ve made some userbars for you !
http://bs0.blogspot.com/2006/06/beos-userbars.htmlI’ve made some userbars for you !
Fair enough
Yep, I know, these are my first.
"]bs0 wrote:http://bs0.blogspot.com/2006/06/beos-userbars.htmlI’ve made some userbars for you !
Fair enough
Heh, I’ll need to grab [Beta]'s version of the bar too
Or - can I just re-use your URL [Beta] ? I don’t have any decent bandwidth to host on.
[Beta wrote:"]bs0 wrote:http://bs0.blogspot.com/2006/06/beos-userbars.htmlI’ve made some userbars for you !
Fair enough
You sure can, if you don’t mind the speed of DSL
You sure can, if you don't mind the speed of DSL :-)
I assume it beats the speed of my IDSL (144/144kbps) - unless you only have 128kbps upstream
Ver Nice.
Could you please make some images with just the Haiku Logo, or even the white ‘Haiku User’ part? I mean, some smaller logos…?
I don’t like when someone changes your work without permission… :?
Use doesn’t mean Edit.
If I would like you to edit them, I’d just post the PSD files…
I’ve put both of the [official bs0] userbars on my host, and everyone’s free to use the links:
http://www.haikuhost.com/images/userbarhaiku.png
http://www.haikuhost.com/images/userbarbeos.png
I’ll add [Beta]'s also, if bs0 gives permission.
I don't like when someone changes your work without permission... :? Use doesn't mean Edit.If I would like you to edit them, I’d just post the PSD files…
To be fair, bs0, you used someone else's image in creating both of these. The Haiku logo is acceptable, but BeOS’s logo is a registered trademark of Palm, Inc. so that’s technically uncool and illegal.
But I understand what you mean. That said, would you please create/endorse a HAIKU TESTER userbar?
Hmm…seems like you’re a little bit bent out of shape about it - so I’ll stop using it until we have permission to use the "tester" version (since "user" doesn’t apply to Haiku quite yet).
On the other hand, I notice that your userbars look very similar to others on the net such as:
http://www.usersigs.com/site/details.php?image_id=1501
With some color alterations, and a logo change - so I’ll have to agree with j_freeman - you aren’t being entirely fair…
Update: looks like a similar bar can be created here:
http://userbarmaker.com/index.php
Just need a good sized logo with transparent background
Are you talking to me?
Because i’d like you to edit them :lol:, seeing as how good the Haiku user bar turned out. All i want is a simply image to put on websites :P.
But that’s certainly ok if you just want them to be User Bars.
Are you talking to me? Because i'd like you to edit them :lol:, seeing as how good the Haiku user bar turned out. All i want is a simply image to put on websites :P.But that’s certainly ok if you just want them to be User Bars.
I don’t think he was referring to you.
There are actually several Haiku logo images available in SVN:
http://svn.berlios.de/viewcvs/haiku/haiku/trunk/data/artwork/
of course you can edit it, keep it on your server etc etc but you could tell me…
and if Palm would take care of BEOS logo, all people having it and showing on google images would be sued.
of course you can edit it, keep it on your server etc etc but you could tell me...and if Palm would take care of BEOS logo, all people having it and showing on google images would be sued.
Thanks
In any case, I figured I would make my own bar anyway since I wanted a TeamHaiku version also - but certainly not out of spite.
I definitely thank you for proposing the idea - and I like the idea of "advertising" Haiku in various forums where I participate.
Maybe we should have a "BeOS/Haiku-related userbar collection" somewhere…
Urias, do you still have separate PNG userbars for TESTER and for TEAM HAIKU? I’d like to put those on my site, in addition to the hybrid one you made (if that’s okay).
Urias, do you still have separate PNG userbars for TESTER and for TEAM HAIKU? I'd like to put those on my site, in addition to the hybrid one you made (if that's okay).
yeah, i posted them here the other day:
http://www.haiku-os.org/forums/viewtopic.php?p=6252#6252
Feel free to "save as" and put them wherever you want - rename them, whatever.
I don’t mind if you modify them also.
