I’m trying to install BeOS 5.0 on a Pentium 3 motherboard, Intel i810e chipset. Booting from the install CD halts at the disc icon, with the following appearing at the point of the halt:
get_module(busses/ide/generic/v0.6): wake failed
get_module(bus_managers/ide/v0.6): wake failed
sysinit1:27
I’ve also tried BeOS Max Edition 4b, Dano, and the Developer Edition 1.1, all of which halt at the same point. The Zeta 1.2 CD boots all the way with no issues. I tried disabling each of the Safe Mode options one by one but still get the same error. The aforementioned BeOS CD’s will boot all the way if I use the general Safe Mode option. I’m thinking it has something to do with IDE drivers. Does anyone have an idea of what the issue is? If I can install BeOS from the CD in Safe Mode, I could hopefully add an updated IDE driver, maybe using a Haiku CD to move the updated driver to the BeOS partition. I wouldn’t be able to use a USB stick in BeOS in Safe Mode since the USB patches only work with user add-ons which Safe Mode disables.
