Hi there,
I am trying to create simple Receipe file, but when trying to make it, I have the following error:
Warning: failure creating the build package: Parse error in .PackageInfo(2:22) -> expected revision number (-<number> suffix)
I do not find the error message to be very useful.
- Is it an issue with the $portVersion not being defied (looking at othr receie, looks like I do not need to do it)?
- Do I need to mention minimum lib versions?
- Something else?
Here is the receipe file I started :
SUMMARY="Basic to C converter"
DESCRIPTION="The name 'BaCon' is an acronym for 'Basic Converter'. \
It is a free BASIC to C translator for Unix-based systems, which \
runs on most Unix/Linux/BSD platforms, including MacOSX. It intends \
to be a programming aid in creating tools which can be compiled on \
different platforms (both 32bit and 64bit), while trying to revive \
the days of the good old BASIC."
HOMEPAGE="https://chiselapp.com/user/bacon/repository/bacon/home"
COPYRIGHT="2009-2023 Peter van Eerten"
LICENSE="MIT"
REVISION="0"
SOURCE_URI="https://chiselapp.com/user/bacon/repository/bacon/attachdownload/bacon-$portVersion.tar.gz?page=Downloads&file=bacon-$portVersion.tar.gz"
CHECKSUM_SHA256="619b721c820e1b11314cd7b88da39db3e76d9063605ee98aa35fb3fe635ab06c"
ARCHITECTURES="all"
PROVIDES="
bacon = $portVersion
cmd:bacon = $portVersion
REQUIRES="
haiku$secondaryArchSuffix
lib:libgtk_3$secondaryArchSuffix
BUILD_REQUIRES="
haiku_devel$secondaryArchSuffix
devel:libgtk_3$secondaryArchSuffix
BUILD_PREREQUIRES="
cmd:make
cmd:gcc
BUILD()
./configure --enable-gui-gtk3 --prefix=/boot/home/config/non-packaged --datadir=/boot/home/config/non-packaged/data
make
INSTALL()
make install
Thanks in advance for the help !
