I tested out the AutoRaise applet and I just have a question on it’s behavior. If I move my mouse from one window to the other it will automatically bring that window to the front. What I did not expect was that if the mouse pointer is moved to hover over the the desktop. All apps then loose focus. Is that expected? I would have assumed, yes I know never assume anything, that AutoRaise would only trigger when moving between open windows and not the desktop.
Yes it is expected.
If the cursor is on the Desktop you cannot write in Terminal for example.
The desktop itself is also a kind of window.
