Audio Randomly Abnormally Quiet
Most of the time ( > 80% ) when booting haiku (R1B5), the audio is incredibly quiet, but then seemingly rarely it boots and decides to be loud again. This sometimes persists for a few reboots, but then after letting the hardware sit for a while, it almost always goes back to being quiet. I’m not sure what the issue is exactly, as even playing in the media settings or restarting the media services doesn’t change anything, the only way it ever switches to or from being quiet is a reboot.
When it’s being quiet, the clipping is noticeable when turning the volume up, and it’s difficult to get a normal volume without speaker static or excessive clipping, or I’d probably just ignore the issue.
I suggest opening a ticket, you can use the tickets below as a reference:
https://dev.haiku-os.org/ticket/18981
https://dev.haiku-os.org/ticket/9438
