I have a Toshiba satellite 1905-S277, installed Beos pro 5.03 on it. Tried the radeon driver version 5.1.3.1 on it but it doesn’t seem to work (nothing happens).
My love/hate story is a long relation punctuated with many install/deinstall…It used to work before with one radeon driver provided on bebits … 2 years ago, any hints?
Besides that, this model used to be quite fit for Beos as everything used to work except the sound card which is a CS4299-A.
Hello Prophet!
This is not so difficult
Firs step: Check the Device ID of Your videocard. (looks like this: 0x4153)
Second step: You need the sources (You can get this from the BeBits), and the DevTools.
Third step: Search and if You dont found, add your videocard DeviceID to the list.
Fourth step: Compile the driver, and put the driver to the correct place. Dont forget the symlink!
I’m hungarian, and my english skill is not the best, but I hope, You can understand me.
Many thanks Miqlas, I fully understand your English, and even if I did not understand (which is not the case), still many thanks.
I will try as soon as possible and give a feedback here
Well, after installation impossible to log into BeOS, so I got fed up and got rid of the partition and put it into ntfs as an archive place. I know that’s not the way to follow for improving things, my apologies. When I’ll be patient enough, I might reinstall BeOS and try to have a beautiful syslog in Xmas…or wait for Haiku…next year bis
–update–
As Xmas is becoming closer, yesterday I was just inspired to reinstall BeOS once more.
I installed the radeon driver from http://www.haikuware.com/view-details/drivers/video/183-haiku-radeon-driver
However…nothing happens.
When I am looking at my Device, my video card is correctly detected with the ID:4c59 (Mobility Radeon M6 16Mo).
I could not find any log in “/var/log” and the directory did not exist either (maybe because nothing happens…)
Could it be that the script provided missed to create some links?
Hello!
The /var directory is hidden. you need write the pathi to the address bar in an Tracker window, and you can see, what contains this directory…
Then You need write this: /var
If You don’t see the path input box, You need enable the navbar in the tracker preferences… (Or You can use the Terminal ( cd /boot/var )
I still do not manage to make it work.
There is an error message in the syslog but it only says that a symbol could not be loaded (doesn’t specify which one). What can I do to have more information?
To be more precise, the message is :
“instantiate_object failed : failed to find an entry defining the class name (Name not found)”
Start hitting [Space Bar] once you see BeOS logo come on the screen ( as soon as computer starts booting into BeOS ). It’ll take you to Safe Mode Boot screen.
Press [Enter] key on “Select safe mode options” to go into it
Go down & select “Enable console debugging” ( use [Space Bar] to select; mark it with a “X” ). This option creates a very detailed syslog which you can go through to see what is failing.
Press [Enter] on “return to main menu”, then [Enter] on “continue booting”
Quentin[/quote]
You should check manually.
For Radeon, I have two files; radeon & radeon.accelerant because I’m user newer drivers. Assumption, your driver is called “radeon” if it is called radeon.driver then change accordingly.
Now, you can also use /boot/home/config/add-ons/…
but I prefer installing drivers to the system ( /boot/beos/system ) vs the user ( /boot/home/config ) directories:
“radeon” goes into
/boot/beos/system/add-ons/kernel/drivers/bin
then you need to create a symbolic link in the following directory
/boot/beos/system/add-ons/kernel/drivers/dev/graphics
( ie: In terminal change to directory above & then type in; ln -s …/…/bin/radeon ); Use ls -l to verify the link. ( ie; radeon -> …/…/bin/radeon )
This link is important to find & use the driver.
“radeon.accelerant” goes into
/boot/beos/system/add-ons/accelerants
Ok, I’ve followed the procedure with “radeon.driver” and it still does not work…
I have the syslog, but which section is interesting as I cannot post the whole think here.
Search it for “radeon”, “ati” & “vesa” and post those lines here:
On my system I have Geforce2 MX & with “radeon” I get the last two lines:
KERN ‘sh’[32]: agp_man: bus module V0.02: init
KERN ‘sh’[32]: agp_man: found 2 AGP capable device(s)
KERN ‘sh’[32]: Radeon - init_hardware: Version: 5.1.6.0
KERN ‘sh’[32]: Radeon - Radeon_CardDetect: no supported devices found
You can also look through syslog for other video cards.
I’m guessing you’re using Vesa mode.
Look in ( config directory ):
/boot/home/config/settings/kernel/drivers
I hope I am not too stupid…, my syslog does not seem so obvious…
The part concerning “radeon”:
KERN ‘app_server’[24]: LOADER: system add-on /boot/beos/system/add-ons/kernel/drivers/bin/radeon.driver linking against kernel.so!
KERN ‘app_server’[24]: vga_init_driver()
KERN ‘app_server’[24]: boot_frame_buffer = 0
KERN ‘app_server’[24]: base_registers (0x00aab508) points to 24 bytes of memory
KERN ‘app_server’[24]: re: base_registers[] - index: 6, vga_count * 6: 6
KERN ‘app_server’[24]: VGA_MAP_MAP_NTH(0) out of 2
KERN ‘app_server’[24]: trying to set 0x002f7acc to 0x30330000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg0 mapping at 0x30330000
KERN ‘app_server’[24]: trying to set 0x002f7ad4 to 0x38330000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg2 mapping at 0x38330000
KERN ‘app_server’[24]: returning the mangled pcii info
KERN ‘app_server’[24]: VGA_MAP_MAP_NTH(1) out of 2
KERN ‘app_server’[24]: trying to set 0x002f7acc to 0x30336000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg0 mapping at 0x30336000
KERN ‘app_server’[24]: trying to set 0x002f7ad4 to 0x38336000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg2 mapping at 0x38336000
KERN ‘app_server’[24]: trying to set 0x002f7acc to 0x3033c000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg0 mapping at 0x3033c000
KERN ‘app_server’[24]: trying to set 0x002f7ad4 to 0x3833c000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg2 mapping at 0x3833c000
KERN ‘app_server’[24]: trying to set 0x002f7acc to 0x30342000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg0 mapping at 0x30342000
KERN ‘app_server’[24]: trying to set 0x002f7ad4 to 0x38342000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg2 mapping at 0x38342000
KERN ‘app_server’[24]: trying to set 0x002f7acc to 0x30348000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg0 mapping at 0x30348000
KERN ‘app_server’[24]: trying to set 0x002f7ad4 to 0x38348000 + 0x00000000
KERN ‘app_server’[24]: create_pci_area: pci_bus1_dev0_func0_reg2 mapping at 0x38348000
Thers is nothing with “ati” and “vesa”, however when I look at
"4c59" (the ID of the VGA card discovered under BeOS in devices manager with Ati technologies as vendor):
I don’t believe the radeon.driver you got was properly compiled for BeOS. Search your system & you’ll see that you don’t have kernel.so library ( used to build Haiku kernel? ). And the driver should not be linking to it anyways. What you have:
What I get in my syslog & you should get too: KERN ‘sh’[32]: Radeon - init_hardware: Version: 5.1.6.0
Actually the line above should detect your Radeon card.
I have Haiku radeon driver compiled for Dano ( BeOS 5.1 ). And may have a compiled version for R5 netserver or bone. I believe the Dano one may also work for you.
Enable your Email in Profile & I can send them to you to try ( best way ) . Or post your email on here like: name[remove-this]@address.com to avoid spam email.
PS I had a Radeon 8500 in my 2nd system & it worked great in BeOS but I moved it over to use on my main system. Also, my onboard CS4236 has sound - hurray and I think the driver supports your sound card too.
I looked & the Haiku driver supports your video card. You just need a version compiled for BeOS & to make sure it gets installed right. Then you’ll finally have 2D accelerated video.
Thank you all for your help. It works now with the driver Euan has posted.
Tonestone, I will be interested in trying your audio driver, though I have doubts it will work.
My email: song(dot)qk(at)gmail(dot)com
I sent the audio driver to Prophet and now his CS4299A works in BeOS.
He is very happy to have accelerated 2D video & sound in BeOS. And his network card works too. So, his system is completely functional and working with BeOS.
