Dear All
i try to build al-anvar on haikudepot but fail with error mentioning phonon…
phonon-dev is installed…
how to fix this problem?
Dear All
Hm. It seems that the program does not linked with phonon library.
… that application exist in depot… and i want to make some code adjustment… before i make change i want to check local haikuporter build but it failed…
try add this lines to the al_anvar.pro file:
haiku {
LIBS += -lphonon4qt5
thanks @3dEyes … its ok now.
