CD: anyboot live CD (TDK brand CD-R) burned and verified with ImgBurn on Windows XP Pro SP3 machine [Dell Inspiron 6400]. md5 checksum of zip file was good.
Hardware:
HP Omnibook XE2-DB notebook
Pentium II 333MHz CPU (yeah, it’s a little slower than you recommend)
256MB RAM (max’ed out)
4.6GB Hard Drive
Teac 24X CD drive (read-only, no burn capability)
800x600 24 bit deep LCD display
Silicon Motion SM811 LynxE video card with 2MB graphics memory (don’t laugh!)
Hi Haiku people!
I wanted to check out Haiku on the 11 year old notebook described under “Hardware” above. I was hoping that, if I liked what I saw using the live CD, I could install Haiku R1 Alpha 2 on my hard drive.
Things started off OK; I got a nice-looking graphic screen (the boot screen?) with several little boxes. There’s one in the middle with what looks to me like a leaf in front of some kind of box. I think the leaf was blinking.
Then BOOM! I got thrown into the kernel debugger. Please don’t ask me to type everything on that screen! It starts off:
PANIC: I/O operation would need to be cut.
Welcome to Kernel Debugging Land…
Thread 12 “main2” running on CPU0
stack trace for thread 12 "main2"
kernel stack: 0x8216c000 to 0x82170000
Then there are 32 frames (0 to 31) listed and finally the “kdebug>” prompt.
I never used an anyboot image before but have done just fine with lots of ISO images. Oh, I changed the ISO and Joliet labels to something that made more sense to me; could that have caused my problem?
Anyway, should I try downloading and burning the ISO image?
I tried booting into safe mode but don’t know if I’m doing it right. Identical results. I held down the shift key while the CD was booting, then selected safe mode options. I used my space bar to put an ‘x’ in front of the Safe mode option, returned to the main menu and selected Continue booting. No joy.
I’ve got Knoppix and Damn Small Linux live CDs that boot OK on this old notebook if I use cheatcodes like fb800x600 and vga=789.
Any help getting the live CD to finish booting so I can see what Haiku might look like on my ancient machine will be much appreciated.
