After installing from HaikuDepot, trying to open any of the apps results in a loaded app with NO windows.
Yep, i’ve had that with ktorrent too, launching it from terminal reveals that it needs a session of dbus running to start up, so you need to type first:
export $(dbus-launch)
Hit enter and then type /path/to/appname
I’ve also built 3 apps from source, namely: kget, kpat and palapeli, all 3 refused to start up without this hack.
Maybe @Diver knows the reason why and hopefully has the solution?
dbus recipe is missing a startup script: https://github.com/haikuports/haikuports/blob/23eed676dd7fa9367c0188947a441c9e948139d7/sys-apps/dbus/dbus-1.10.22.recipe
Something like this https://github.com/haikuports/haikuports/blob/7fe4819e72d82f5298a4b889a8076799a7503c57/haiku-apps/lnlauncher/lnlauncher-1.1.2.recipe#L49
needs to be done there.
Is there a way to get rid of dbus as a dependency at least just for the start up part of the apps
Only some apps can be configured to not use dbus. Calligra doesn’t need it for runtime but it crashes on save without dbus being installed.
Does not fully load on my rig…just see the icon in the desk bar, but no windows, even if I use ‘dbus-launch’ to start it (Words, Plan, Sheets, Karbon, Stage, etc.).
Does launching it from Terminal reveals any other info?
Just this…
~> dbus-launch /system/apps/Calligra/Words
calligra.lib.pigment: Legacy integer arithmetics implementation
Odd… Run this:
kbuildsycoca5 --global
and try again.
Same result…app icon, no windows. Here is the CL output for the command:
~> /boot/system/bin/x86/kbuildsycoca5 --global
kbuildsycoca5 running…
“applications.menu” not found in ()
kf5.kservice.sycoca: Service type not found: "image/openraster"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.spreadsheet"
kf5.kservice.sycoca: Service type not found: "application/x-quattropro"
kf5.kservice.sycoca: Service type not found: "application/vnd.ms-excel"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.formula"
kf5.kservice.sycoca: Service type not found: "application/x-kchart"
kf5.kservice.sycoca: Service type not found: "application/x-wpg"
kf5.kservice.sycoca: Service type not found: "application/x-vnd.kde.plan"
kf5.kservice.sycoca: Service type not found: "image/tiff"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.spreadsheet-template"
kf5.kservice.sycoca: Service type not found: "image/x-portable-pixmap"
kf5.kservice.sycoca: Service type not found: "image/wmf"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.presentation"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.text"
kf5.kservice.sycoca: Service type not found: "video/x-mng"
kf5.kservice.sycoca: Service type not found: "application/vnd.openxmlformats-officedocument.wordprocessingml.template"
kf5.kservice.sycoca: Service type not found: "application/vnd.ms-powerpoint"
kf5.kservice.sycoca: Service type not found: "application/vnd.wordperfect"
kf5.kservice.sycoca: Service type not found: "image/x-portable-bitmap"
kf5.kservice.sycoca: Service type not found: "image/x-xbitmap"
kf5.kservice.sycoca: Service type not found: "image/x-xfig"
kf5.kservice.sycoca: Service type not found: "image/x-xpixmap"
kf5.kservice.sycoca: Service type not found: "application/x-mswrite"
kf5.kservice.sycoca: Service type not found: "image/gif"
kf5.kservice.sycoca: Service type not found: "text/csv"
kf5.kservice.sycoca: Service type not found: "application/illustrator"
kf5.kservice.sycoca: Service type not found: "image/vnd.microsoft.icon"
kf5.kservice.sycoca: Service type not found: "application/rtf"
kf5.kservice.sycoca: Service type not found: "multipart/x-mixed-replace"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.graphics-template"
kf5.kservice.sycoca: Service type not found: "application/pdf"
kf5.kservice.sycoca: Service type not found: "image/svg+xml"
kf5.kservice.sycoca: Service type not found: "image/bmp"
kf5.kservice.sycoca: Service type not found: "application/x-iwork-keynote-sffkey"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.formula-template"
kf5.kservice.sycoca: Service type not found: "multipart/mixed"
kf5.kservice.sycoca: Service type not found: "application/vnd.openxmlformats-officedocument.wordprocessingml.document"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.graphics"
kf5.kservice.sycoca: Service type not found: "image/jpeg"
kf5.kservice.sycoca: Service type not found: "image/x-jng"
kf5.kservice.sycoca: Service type not found: "application/msword"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.text-template"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.text-master"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.presentation-template"
kf5.kservice.sycoca: Service type not found: "application/vnd.openxmlformats-officedocument.spreadsheetml.sheet"
kf5.kservice.sycoca: Service type not found: "application/x-java-applet"
kf5.kservice.sycoca: Service type not found: "application/vnd.openxmlformats-officedocument.presentationml.template"
kf5.kservice.sycoca: Service type not found: "application/vnd.openxmlformats-officedocument.presentationml.presentation"
kf5.kservice.sycoca: Service type not found: "text/plain"
kf5.kservice.sycoca: Service type not found: "application/postscript"
kf5.kservice.sycoca: Service type not found: "image/png"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.chart"
kf5.kservice.sycoca: Service type not found: "application/vnd.ms-works"
kf5.kservice.sycoca: Service type not found: "image/x-tga"
kf5.kservice.sycoca: Service type not found: "application/x-java"
kf5.kservice.sycoca: Service type not found: "application/vnd.openxmlformats-officedocument.spreadsheetml.template"
kf5.kservice.sycoca: Service type not found: "image/x-portable-graymap"
kf5.kservice.sycoca: Service type not found: "application/x-khtml-adaptor"
kf5.kservice.sycoca: Service type not found: "application/vnd.oasis.opendocument.chart-template"
kf5.kservice.sycoca: Service type not found: "text/html"
kf5.kservice.sycoca: Service type not found: "application/x-kspread"
kf5.kservice.sycoca: Service type not found: "image/svg+xml-compressed"
kf5.kservice.sycoca: Service type not found: "application/xml"
kf5.kservice.sycoca: Service type not found: "application/x-kpresenter"
kf5.kservice.sycoca: Service type not found: “application/x-karbon”
