Ahoy dear devs,
After getting fix for a memory leak in Beta 4 recently (#18724),
and read about a memory leak fix
in ticket #18585 also
meanwhile remembered a Mediaplayer issue (#18654) that was fixed for memory leak as well in ffmpeg …
Can we get such memory leak fixes in Beta4 ?
I searched for ‘Memory leak’ among tickets
to collect recent ones
1 → to have the correct ticket numbers
2-> to see what was already enabled in Beta4
– ticket #18724 : we got the fix in Beta4 recently - thanks for it !
– ticket #18654 : look at below, I enlist the fix for asking about ,
as still not applied for Beta4
– ticket #18585 : look at below, I enlist the fix for asking about ,
as patiently waiting for answer : can be applied soon ?
– ticket #18357 :
Deskbar originated memory leak by mentioned vector bitmap change -
I am uncertain about that it relates to Beta4 as the change number was not written in the ticket and mentined hrevs were after Beta4 released, so that change might not applied for r1beta4 even by selected revisions/patches.
At first sight it seems does not relate as it was fixed by reverting that change possibly relates only for master branch.- aka nightlies.
– ticket #18344 : the memory leak fix here was already backported to Beta4 by ticket history
– ticket #18266 : it was not a memory leak issue after peek in
– ticket #18200 : still not fixed by ticket history
I found no more recent ones, at least with ‘Memory leak’ filter …
Also checked r1beta4 branch on Gerrit.
I found more ffmpeg fix in beta4 branch branch, but not the following
ffmpeg: fix leak when decoding audio frames hrev57382
which was the above mentioned ffmpeg memory leak fix of ticket #18654.
Of course, as #18585 just fixed recently … we can wait for application, as usual
but we would be happy if both mentioned network patches would be selected for applications - altogether with ffmpeg one -
in r1beta4 branch.
Thanks for your consideration and reply -
