Here is my output from `
listdev
Welcome to the Haiku shell.
~> listdev
device Serial bus controller (SMBus) [c|5|0]
device a123: 100 Series/C230 Series Chipset Family SMBus
device a170: 100 Series/C230 Series Chipset Family HD Audio Controller
device Memory controller [5|80|0]
device a121: 100 Series/C230 Series Chipset Family Power Management Controller
device a143: H110 Chipset LPC/eSPI Controller
device Serial bus controller (USB controller, XHCI) [c|3|30]
vendor 1b21: ASMedia Technology Inc.
device 1242: ASM1142 USB 3.1 Host Controller
device a118: 100 Series/C230 Series Chipset Family PCI Express Root Port #9
vendor 10ec: Realtek Semiconductor Co., Ltd.
device 8168: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
device a117: 100 Series/C230 Series Chipset Family PCI Express Root Port #8
device a114: 100 Series/C230 Series Chipset Family PCI Express Root Port #5
device Mass storage controller (SATA controller, AHCI 1.0) [1|6|1]
device a102: Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode]
device Communication controller [7|80|0]
device a13a: 100 Series/C230 Series Chipset Family MEI Controller #1
device a12f: 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller
vendor 1002: Advanced Micro Devices, Inc. [AMD/ATI]
device aae0: Baffin HDMI/DP Audio [Radeon RX 550 640SP / RX 560/560X]
device 67ff: Baffin [Radeon RX 550 640SP / RX 560/560X]
device 1901: 6th-10th Gen Core Processor PCIe Controller (x16)
device Bridge (Host bridge) [6|0|0]
device 591f: Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers
~> Baffin [Radeon RX 550 640SP / RX 560/560X]
But the Baffin driver does not work and I have to boot with safe vesa!
I have waited hours on the black screen and nothing happens
Here is sysinfo ouput:
~> sysinfo
Kernel name: kernel_x86_64 built on: Aug 25 2021 06:25:44 version 0x1
4 Intel Core™ i5-7500, revision 906e9 running at 3408MHz
CPU #0: “Intel(R) Core™ i5-7500 CPU @ 3.40GHz”
Signature: 0x0906e9; Type 0, family 6, model 158, stepping 9
Features: 0xbfebfbff
FPU VME DE PSE TSC MSR PAE MCE CX8 APIC SEP MTRR PGE MCA CMOV PAT
PSE36 CFLUSH DS ACPI MMX FXSTR SSE SSE2 SS HTT TM PBE
Extended Features (0x00000001): 0x7ffafbff
SSE3 PCLMULDQ DTES64 MONITOR DS-CPL VMX SMX EST TM2 SSSE3 SDBG FMA CX16 xTPR PDCM PCID
SSE4.1 SSE4.2 x2APIC MOVEB POPCNT TSC-DEADLINE AES XSAVE OSXSAVE AVX F16C RDRND
Extended Features (0x80000001): 0x2c100800
SCE NX GBPAGES RDTSCP 64
L2 Data cache fully associative, 1 lines/tag, 64 bytes/line
L2 cache: 256 KB, 8-way set associative, 0 lines/tag, 64 bytes/line
Data TLB: 2M/4M-bytes pages, 4-way set associative, 32 entries
Data TLB: 4k-byte pages, 4-way set associative, 64 entries
Code TLB: 2M/4M pages, fully associative, 8 entries
Code TLB: 4K-bytes pages, 8-way set associative, 128 entries
64-byte Prefetching
Shared 2nd-level TLB: 4K/2M, 6-way set associative, 1536 entries
CPU #1: “Intel(R) Core™ i5-7500 CPU @ 3.40GHz”
64-byte Prefetching
CPU #2: “Intel(R) Core™ i5-7500 CPU @ 3.40GHz”
64-byte Prefetching
CPU #3: “Intel(R) Core™ i5-7500 CPU @ 3.40GHz”
64-byte Prefetching
15832076288 bytes free (used/max 1284644864 / 17116721152)
(cached 545021952)
64124 semaphores free (used/max 1412 / 65536)
3872 ports free (used/max 224 / 4096)
3913 threads free (used/max 183 / 4096)
2024 teams free (used/max 24 / 2048)
I have tried all and every troubleshooting settings for booting to no avail.
I know that there are bug reports already lodged , so I wont be raising another one!
