Haiku Alpha1 was working fine in my pc. I installed Alpha2 over Alpha1, it was still working fine. Then I decide to clean up the old system. I just delete and recreate the partition. Then install the Alpha2 to my Dell Latitude C640. It is booting from the CD successfully, installing without error. But not booting from hard disk.
First I created the partition from Haiku disk. It was saying problem booting the operating system. Then I created the partition from XP disk, then initialize it from Haiku with the default options. It is now saying no bootable disk found.
First, are you installing this as the only OS onto the C640, or do you have other data/partitions on it? I’m a little unsure about my instructions below, so if you value your data, check on what you’re doing ;). With that out of the way:
